Been tarting my engine bay up and have inadvertently caused an issue.
Firstly when I put the key to the on position (not start position) the starter motor engages which is obviously incorrect, I tested each wire at the starter relay connector and they responded as expected. I then took the cover off the relay and the relay intermittently switched when the key was in the wrong position so I'll replace the relay just as a measure. Also The ground from the relay goes to a multi pin connector in the engine bay fuse box, when I tested this back to the chassis it gave a reading, I was expecting to see no resistance?
Second problem is I'm not seeing a spark, (I bypassed the starter relay and wired up a button switch and put the key to on) the power is making it to the fuse for the ignition coil but I'm not getting a reading on the lead to the distributor.
Does the ignition and starter system share a common earth that I may have not connected to cause both these issues? And if so where is it located? Or any other thoughts?
Hope you guys can help.
[Mk2] [Turbo] Ignition/ starter issue
- Driftlimits Performance
- IMOC Affiliated Company
Re: [Mk2] [Turbo] Ignition/ starter issue
Your problem is the earth on the bottom of the inlet manifold. Or the lack of.
You were 100% correct. 👍
