MK1a / MK1b Clutch Slave Cylinder and Rod difference?
Author Message
playmonkey
PostPosted: Tue May 02, 2017 6:24 pm    Post subject: MK1a / MK1b Clutch Slave Cylinder and Rod difference? Reply with quote Reply with quote including images
Continuing saga of my engine transplant. Just gone to move the car for the first time since changing the engine and box from a MK1b to my MK1a.
I decided to leave the clutch slave cylinder on the car so I wouldn't have to bleed it [Rolling Eyes] but have just come up with a floppy clutch pedal. I'm pretty sure that the clutch plate has not stuck... well, I suppose it could have - hmmmm
Anyways - question....
Are the clutch slave cylinders and push rods the same on the MK1a and the MK1b and... if the clutch has stuck on....
Best way of freeing it? I've already started the car with it in gear - that was exciting as I only have about five feet until a solid object!
Thanks in advance.
PM
Back to top
User is offline
Lauren
PostPosted: Thu May 04, 2017 5:06 am    Post subject: Reply with quote Reply with quote including images
I thought the slaves were the same, I could be wrong.
I've had the clutch stick on the AE86 once when it had been sitting a couple of years. I just did it on the starter, soon free'd it off.
_________________
2013 GT86 Injen Induction. Volks Racing TE37s & TRD Aero Fins, Mega sounds. TEIN Street Flex 5/6kg, TEIN EDFC Active Pro. Tuning Developments Remap 4-1 Manifold, TD resonated exhaust, decat/overpipe, AP Racing 4 Pot front brakes. [lover]
Back to top
User is offline
PW@Woodsport
IMOC Affiliated Company
PostPosted: Thu May 04, 2017 2:22 pm    Post subject: Reply with quote Reply with quote including images
Clutch slaves are all identical from 84-89, as it the clutch slave push rod, all identical.
Did you change the clutch or fit the whole engine gearbox from another car complete as one unit?
It sounds to me like either the release bearing is not installed properly or some other clutch installation fault.
If you never opened up the clutch hydraulic circuit the issue must be inside the bellhousing.
_________________
Back to top
User is offline
SuperRedMR2
1990 Toyota MR2 Mk1b
PostPosted: Thu May 04, 2017 3:50 pm    Post subject: Reply with quote Reply with quote including images
Did you put the clutch plate on the right way around?
Sounds silly but this happened to me when changing a clutch 15 years ago on a Triumph Acclaim.
Back to top
User is offline
playmonkey
PostPosted: Thu May 04, 2017 8:22 pm    Post subject: Reply with quote Reply with quote including images
Thanks for the replies.
Both cars were driving fine, gearbox and clutches ok.
I took the engine and box out of the 1b and put the whole thing in my 1a.
Never split the engine/box. I left the hydraulics intact when changing and just bolted the slave back on the replaced unit.
I've only just noticed because I needed to move the car. it never occurred to me that it wouldn't be working....
I'll have to have a closer look I suppose, but it's very odd and unexpected.
Also, for some reason the car won't roll easily. Two of us couldn't push her easily but it's definitely not turning the engine when pushing.
All very strange.
Back to top
User is offline
jimzzr
PostPosted: Sun May 07, 2017 9:15 pm    Post subject: Reply with quote Reply with quote including images
Is the clutch arm actually moving when the clutch is pressed?
You say floppy pedal is there any resistance? - I've had the seal stick in the master cylinder before when trying to bleed - i.e. relying on the spring in the master cylinder to push the seal back whereas in normal operation the force of the clutch overcomes any stickiness.
Back to top
User is offline
playmonkey
PostPosted: Sun Jun 04, 2017 11:50 am    Post subject: Reply with quote Reply with quote including images
Sorry, been away for a while. Going to check on the movement when i can get someone to sit in the car and press the pedal. Ta
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
