FOG LIGHT SWITCH WIRING
Tony jinxy froude
Post by Tony jinxy froude »
Hi guys, I have acquired a mk2 fog light switch for using on my MK1 JDM motorised fog lamps, the problem I have is that I cant identify which wires are supposed to go where as I cant find a wiring diagram for the MK2, any help would be appreciated, cheers, Jinxy
simpson_eh
Re: FOG LIGHT SWITCH WIRING
Post by simpson_eh »
i have done this but with a meter and a few blown fuses still cant get the switch to light up though, so watching this post :)
abovetherim
Post by abovetherim »
You can download some wiring diagrams here
https://1drv.ms/b/s!Aof644c8-zKGgxArBrcRtRo0NFd0
abovetherim
just copy the link into your browser address bar without the url bit
Tony jinxy froude
Thanks very much for the link it's much appreciated, I've established that the red is live, White & black is earth and the yellow & Green are both power out once switched. I've decided to get an auto electrician to fit them in properly as I don't trust my own electrical expertise, but will post pics once finished 👍👍
