4AGZE OEM HG
Author Message
SuperRedMR2
1990 Toyota MR2 Mk1b
PostPosted: Fri Apr 14, 2017 4:55 pm    Post subject: 4AGZE OEM HG Reply with quote Reply with quote including images
I need to change the head gasket on my 4AGZE prior to install.
It looks like its had a bit of leakage so just a precaution I want to change it.
However, I cannot find a head gasket other than MLS.
Is Toyota the only source for a standard head gasket, of decent quality that is?
Back to top
User is offline
kaiowas
1985 Toyota MR2 Mk1a
PostPosted: Sat Apr 15, 2017 9:56 am    Post subject: Reply with quote Reply with quote including images
There's nothing special about a GZE HG. You can use any of the multitude that are available for the n/a engine. Having said that I usually lean towards using a genuine Toyota HG and generally end up buying the full gasket kit so that I have new replacements for anything else I might need. I think I've also got an uprated aftermarket gasket of some kind (possibly TRD) that I'd probably use next time I need to replace one.
Back to top
User is offline
knocker
PostPosted: Sat Apr 15, 2017 11:06 am    Post subject: Head Gasket Reply with quote Reply with quote including images
Hi try TCB Trevor or Paul they supplied OEM for my SC
Back to top
User is offline
SuperRedMR2
PostPosted: Sat Apr 15, 2017 12:07 pm    Post subject: Reply with quote Reply with quote including images
I have found the Toyota part Numbers for both na and sc.
But Toyota do not open again til tuesday- just hope they can order me one by Friday.
Back to top
User is offline
Lauren
PostPosted: Sat Apr 15, 2017 2:55 pm    Post subject: Reply with quote Reply with quote including images
I would only use OEM too and take Phil's advice about getting a head gasket kit as there are bound to be other gaskets and o rings etc that could do with being changed.
Toyota can usually get these parts in a couple of days or so.
_________________
1985 AE86 Sprinter Trueno GT-Apex [lover]
2013 GT86 Miltek Exhaust, decat/overpipe Injen Induction. Volks Racing TE37s & TRD Aero Fins, Mega sounds. TEIN Street Flex 5/6kg, TEIN EDFC Active Pro. Tuning Developments Remap [lover]
Back to top
User is offline
SuperRedMR2
PostPosted: Sat Apr 15, 2017 11:05 pm    Post subject: Reply with quote Reply with quote including images
I have bought only the essential gaskets separately, but will order the HG from Toyota. If they order it tuesday, I should be able to pick it up on Friday.
Back to top
User is offline
SuperRedMR2
PostPosted: Tue Apr 18, 2017 9:09 am    Post subject: Reply with quote Reply with quote including images
Cannot get a standard OEM HG before the 7th July....
Back to top
User is offline
jon_st205
PostPosted: Tue Apr 18, 2017 10:29 am    Post subject: Reply with quote Reply with quote including images
Could try the guys at http://hurleyraceengineering.co.uk - maybe they'll have one in stock.
Back to top
User is offline
knocker
PostPosted: Tue Apr 18, 2017 12:19 pm    Post subject: HG Reply with quote Reply with quote including images
TCB will get it for you quicker and OEM. I use them for any OEM parts and they are usually at a lower cost.
Back to top
User is offline
SuperRedMR2
PostPosted: Tue Apr 18, 2017 1:18 pm    Post subject: Reply with quote Reply with quote including images
I've ordered one from TCB but it's not a Toyota gasket, however it's being sent to me for tomorrow.
I've used TCB before and they are always very good.
Back to top
User is offline
Lauren
PostPosted: Tue Apr 18, 2017 7:04 pm    Post subject: Reply with quote Reply with quote including images
If there is one thing I would only fit OEM it would be the head gasket. It's the kind of job you only want to do once really.
But your choice of course.
Back to top
User is offline
SuperRedMR2
PostPosted: Tue Apr 18, 2017 8:01 pm    Post subject: Reply with quote Reply with quote including images
Well being told the 7th is July is ridiculous. I've bought Toyota rod bolts, nuts, timing belt guide and pulley to make up for it.
That lead time was for the 4age and 4agze head gaskets. So anyone needing one on the quick has no chance. Good price but 2.5 months is crazy
Back to top
User is offline
PW@Woodsport
IMOC Affiliated Company
PostPosted: Wed Apr 19, 2017 6:26 am    Post subject: Reply with quote Reply with quote including images
The Toyota parts system only gives a rough initial estimate though on enquiry, the delivery dates radically change the second they actually place the order on the system. I've had Toyota quote me 2 months delivery before but as soon as I actually place the order it refreshes as a week or two max.
I've been using Lancaster Toyota in Durham for over 20 years now and this has always been the way it works.
I am on first name terms with our parts department, I will place the order for a HG today and see what the actual lead time is for you. I'm always using 4a-ge HGs so no problem keeping one in stock.
I too would never use any other HG than OEM.
_________________
Back to top
User is offline
SuperRedMR2
PostPosted: Wed Apr 19, 2017 8:54 am    Post subject: Reply with quote Reply with quote including images
Hi Paul,
Unfortunately I do not have that sort of familiarity with the Parts guys at Toyota and can only go by what I have been told.
I'll have my HG from TCB today so don't worry Paul. I've never used an OEM gasket and never had issues. I've even reused a metal HG and that's still running fine, but each to their own.
Back to top
User is offline
SuperRedMR2
PostPosted: Wed Apr 19, 2017 12:36 pm    Post subject: Reply with quote Reply with quote including images
Out of curiosity, what is the Toyota HG rated to in terms of power? Mine will be putting out more than 145hp.
Back to top
User is offline
Lauren
PostPosted: Wed Apr 19, 2017 8:15 pm    Post subject: Reply with quote Reply with quote including images
Mine made 186bhp. You won't make over 180bhp with an early engine. The stock head gasket is absolutely fine.
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
