What brake fluid?.
Author Message
Tiger Tim
PostPosted: Sun Apr 09, 2017 7:16 pm    Post subject: What brake fluid?. Reply with quote Reply with quote including images
Hi all,
I pulled out my MK1A for a spin today & all went well except the brake pedal which is very spongy.Car has been under covers in the garage for most of the winter. Pumping the brakes improves the brake pedal. Guess I'd better bleed the brakes & check sliders. Last time I replaced the brake fluid about 2 years ago I used DOT4. Car is just used for vintage runs so not too much spirited driving. Is DOT4 what you use & is any make recommended. I've heard people mention silicone fluid but brake system may need to be flushed first to remove all traces of DOT4. Not sure if that is an option. What do you recommend?.
Thanks,
Tim
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Sun Apr 09, 2017 8:28 pm    Post subject: Reply with quote Reply with quote including images
DOT4 is fine for a road car.
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
