[Mk2] [Turbo] What re these wires for?
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical
Author Message
markstevieandmads
PostPosted: Fri Mar 31, 2017 7:34 pm    Post subject: [Mk2] [Turbo] What re these wires for? Reply with quote Reply with quote including images
As per pic really. I have one spade connector with blue wire, and 2 multiplugs.
Im sure the one with the brown wires went to a sensor in the old cat that was removed and replaced with a decat. I guess i can just leave this unplugged?
But im unsure of the other two.
Back to top
User is offline
Bear87
Premium Member
PostPosted: Fri Mar 31, 2017 8:45 pm    Post subject: Reply with quote Reply with quote including images
The single spade connector is likely a lamda sensor if it's a rev1 or 2 as rev 3 onward were 4 wire (I may be corrected) only other plugs in that area are air con pump and intercooler fan.
_________________
Smoke me a kipper. I'll be back for breakfast.
1992 Rev 2 Turbo Super Red
1991 Rev 1 N/A Steel Mist Grey (daily)
Back to top
User is offline
markstevieandmads
PostPosted: Fri Mar 31, 2017 8:49 pm    Post subject: Reply with quote Reply with quote including images
The spare isnt the lamda as got a connector for that already. I wonder if its an earth for somewhere.
I think you maybe right in the intercooler fan and air con as ive temoved both of these so wont be needed now.
Back to top
User is offline
Bear87
Premium Member
PostPosted: Fri Mar 31, 2017 8:53 pm    Post subject: Reply with quote Reply with quote including images
From factory you have a pre cat and post cat sensor both single wire. I don't know of a earth wire that runs into the factory loom but if your wiring is anything like mine then anything is possible [Brick wall]
I have my air con removed too and every time I see the plug hanging around it throws me!
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical All times are GMT
Page 1 of 1
Jump to:
