CV JOINT/ DRIVE SHAFT
Gi guys . Can anyone recommend where on this earth i can source a 3sgte drive shaft . Or just the cv joint .
Re: CV JOINT/ DRIVE SHAFT
I got a pair of 3sge ones. No idea if they are compatible
If you have abs then you need a cv joint with the abs tone/reluctor ring installed. Otherwise you'll have to re-install your old abs ring.
