Rev 3
Ralliart
Rev 3
Post by Ralliart »
now sorted
[email protected]
Re: Rev 3
Post by [email protected] »
Fuel cut out?
Ralliart
Re: Rev 3
Post by Ralliart »
thats what it feels like but didnt think even when stationary being revved would cause this.........??
markstevieandmads
Re: Rev 3
Post by markstevieandmads »
Have u got the wrong ignitor or coil on there. I seem to remember rev 1/2 had this problem when doing a rev 3 conversion and one of these wasnt swapped out.
androo007
Re: Rev 3
Post by androo007 »
I assume you aren't hitting fuel cut? What peak boost reading do you see?
Ralliart
Re: Rev 3
Post by Ralliart »
no
MartinF
Re: Rev 3
Post by MartinF »
androo007 wrote:I assume you aren't hitting fuel cut? What peak boost reading do you see?
There won't be any boost when stationary.
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
Re: Rev 3
markstevieandmads wrote:Have u got the wrong ignitor or coil on there. I seem to remember rev 1/2 had this problem when doing a rev 3 conversion and one of these wasnt swapped out.
Yep. Classic sign of a rev1/2 igniter fitted to a Rev 3 turbo engine.
Ralliart
Re: Rev 3
Post by Ralliart »
mine is a genuine rev3 turbo car so cant understand why someone would change the ignitor to a rev2 one ?
Anyway of finding out without removing i.e any visible difference betweek an earlier rev to rev3 ?
Am I right in thinking the ignitor is under the fuse box in the engine bay.
markstevieandmads
Re: Rev 3
Ralliart wrote:mine is a genuine rev3 turbo car so cant understand why someone would change the ignitor to a rev2 one ?
Its quite possible that a previous owner had a fault and replaced the part. Not sure what the differences are though but do know they are different.
Ralliart
Re: Rev 3
Post by Ralliart »
sorted
markstevieandmads
Re: Rev 3
as previously posted, it earths through that bracket so it wouldnt start if it was off the bracket.
Ralliart
Re: Rev 3
Post by Ralliart »
sorted
Ralliart
Re: Rev 3
Post by Ralliart »
Hez
Re: Rev 3
Post by Hez »
The rev needle might be in the wrong place / damaged :D
Ralliart
Re: Rev 3
Post by Ralliart »
lol think it was wishful thinking on my part :) needles seem fine atleast it idles spot on at 900rpm so I assume its all good..
Ralliart
Re: Rev 3
Post by Ralliart »
Ralliart
Re: Rev 3
Post by Ralliart »
