3sgte gen2 blitz ecu for 540cc injectors
Parts for the Mk2 MR2 only (excluding bodywork and wheels/tyres)
Maslalt
Post by Maslalt »
So have for sale blitz acces ecu 3sgte gen2. This ecu have fuel map for 540cc injectors from gen3 3sgte. Boost 18psi. Later will add foto.
Price not shure. Will someone be intrested?
Tomas_St
Re: 3sgte gen2 blitz ecu for 540cc injectors
Post by Tomas_St »
[-( how you change map? its does not have any port
Maslalt
Post by Maslalt »
It was both like this. You cant change maps. You need put 540cc injectors into your rail and only then put this ecu. This ecu is now in celica st185. This celica have ct20b turbo, 540cc gen3 injectors, strihgt exhaust 3in and sport intake. Boost is set for 18psi and at full boost it runs at 11.5-11.8afr. Just dont know how much power it delivers.
Selling this ecu becouse we gona put aem ems stand alone into this celica.
Tomas_St
Post by Tomas_St »
Maslalt wrote:It was both like this. You cant change maps. You need put 540cc injectors into your rail and only then put this ecu. This ecu is now in celica st185. This celica have ct20b turbo, 540cc gen3 injectors, strihgt exhaust 3in and sport intake. Boost is set for 18psi and at full boost it runs at 11.5-11.8afr. Just dont know how much power it delivers.
hmmm strange i got same ecu but not for 540cc injectors in mr2 rev 2
SonicSW20
Post by SonicSW20 »
They are mapped to the customers spec by Blitz when purchased. A Gen2 Blitz ECU mapped for 540's is unusual, but not unheard of.
Maslalt
Post by Maslalt »
Funny story. This ecu was both like regular blitz ecu for gen2 3sgte. But then it was put into car my friend blown 2 knock sensors and car runned crapy. Then he asked me to check everifiking to find what is going on. I put wideband. And found out that car is runing realy lean. Then car is cold started afr there 16 and it started badly lean out from 10psi. So this is how we found out this ecu need 540cc injecters. After puting biger injecetors everifing started to work corectly.
Maslalt
Post by Maslalt »
Price 450£ posted
Return to “Mk2”
