4AGZE Conversion
Goto page Previous  1, 2
Author Message
SuperRedMR2
1990 Toyota MR2 Mk1b
PostPosted: Thu Apr 06, 2017 12:15 pm    Post subject: Reply with quote Reply with quote including images
In regards to the air con compressor - does it just un-bolt or does it have anything to do with the alternator bracket?
Back to top
User is offline
Lauren
PostPosted: Thu Apr 06, 2017 3:11 pm    Post subject: Reply with quote Reply with quote including images
It's on the other side of the engine to the alternator, so I'm sure they are totally separate.
_________________
2013 GT86 Injen Induction. Volks Racing TE37s & TRD Aero Fins, Mega sounds. TEIN Street Flex 5/6kg, TEIN EDFC Active Pro. Tuning Developments Remap 4-1 Manifold, TD resonated exhaust, decat/overpipe, AP Racing 4 Pot front brakes. [lover]
Back to top
User is offline
jon_st205
PostPosted: Thu Apr 06, 2017 3:29 pm    Post subject: Reply with quote Reply with quote including images
Same side on the MR2 'ZE.
Back to top
User is offline
Lauren
PostPosted: Thu Apr 06, 2017 5:05 pm    Post subject: Reply with quote Reply with quote including images
Yeah, I did wonder that! Would make sense with the SC I guess!
I've got a 4AGZE in the shed, but it's the other end of my short garden. I think you'll just have to have a look. They may well be as I know on my AE the power steering and AC are on the same bracket.
Back to top
User is offline
SuperRedMR2
PostPosted: Thu Apr 06, 2017 9:42 pm    Post subject: Reply with quote Reply with quote including images
Got it off.
Air con compressor and bracket weigh in at 6.4kg - nice to shed some weight as easily as removing that.
Mine doesn't have the oil cooler hose inlet on the sump.
Back to top
User is offline
jon_st205
PostPosted: Fri Apr 07, 2017 9:25 am    Post subject: Reply with quote Reply with quote including images
JDM's, including the S/C, don't have the oil heat exchanger setup. You could retrofit I guess, but if you want to save weight I wouldn't bother.
Back to top
User is offline
SuperRedMR2
PostPosted: Fri Apr 07, 2017 11:04 am    Post subject: Reply with quote Reply with quote including images
Hi Jon,
I already have the oil cooler bolted on to my N/A so it'd just be a matter of getting some flexi hose and robbing the old parts off my current engine.
However I suffer from low pressure on my N/A so I'm not sure I want to re-use my existing cooler.
Back to top
User is offline
Display posts from previous:
Page 2 of 2
Jump to:
