4AGZE Conversion
Goto page 1, 2  Next
Author Message
SuperRedMR2
1990 Toyota MR2 Mk1b
PostPosted: Thu Mar 16, 2017 10:38 am    Post subject: 4AGZE Conversion Reply with quote Reply with quote including images
Hi all,
I am in the process of purchasing a complete 4AGZE clip, complete with ECU, loom etc etc
A few questions:
Do I need to upgrade the pump? I am sticking to the standard size SC pulley for now but I may upgrade in the future (finances a bit low at the moment).
I can easily have the N/A engine lid modified and I was going to design a vent that can be welded onto the existing lid for airflow to the IC.
But should I make an air duct from the fan/vent pod on the drivers side to the IC? This isn't a real bind either as this can be made at work.
Anything I should be aware about being installation?
Many thanks in advance.
Alex
Back to top
User is offline
Lauren
PostPosted: Thu Mar 16, 2017 7:23 pm    Post subject: Reply with quote Reply with quote including images
You don't need to upgrade the pump, but you do need an adjustable fuel pressure regulator that will need setting up on a rolling road as the SC one is lower pressure on the return.
This is essential if you want to run a big pulley. You also need to block off the ABV. I had a new SC outlet pipe made doing away with it all together.
The engine lid needs to seal with the IC to get the best effect. An SC engine lid is the best way of course. Can look a bit crap if you modify an NA lid.
You can seal the intercooler off from the engine bay as I did here back in 2003 for my track car:
http://www.mr2.net/trackdayqueen/beardpt2.htm
But unless you are going to do track days I wouldn't worry about it.
Is the engine out of an MR2 or AE92/AE101?
_________________
2013 GT86 Injen Induction. Volks Racing TE37s & TRD Aero Fins, Mega sounds. TEIN Street Flex 5/6kg, TEIN EDFC Active Pro. Tuning Developments Remap 4-1 Manifold, TD resonated exhaust, decat/overpipe, AP Racing 4 Pot front brakes. [lover]
Back to top
User is offline
SuperRedMR2
PostPosted: Thu Mar 16, 2017 8:49 pm    Post subject: Reply with quote Reply with quote including images
Mr2
I can get the abv pipe made at work.
SC lids are not very easy to obtain that is the problem.
Back to top
User is offline
autobody
Premium Member
1988 Toyota MR2 Mk1 SC
PostPosted: Thu Mar 16, 2017 10:30 pm    Post subject: Reply with quote Reply with quote including images
I can't help with the conversion answers but here is Toni old engine lid on ebay:
http://www.ebay.co.uk/itm/Toyota-MR2-Mk1-Supercharger-engine-lid-/322441579679?fits=Model%3AMR+2&hash=item4b13040c9f:g:PVgAAOSw32lYuovs
Back to top
User is offline
SuperRedMR2
PostPosted: Thu Mar 16, 2017 11:19 pm    Post subject: Reply with quote Reply with quote including images
Ah thanks for the link. Not got any money for that though plus doesn't that kid need to be modified to suit my latch?
Back to top
User is offline
Lauren
PostPosted: Fri Mar 17, 2017 7:10 am    Post subject: Reply with quote Reply with quote including images
You just move the latch on the car, it's not actually that hard to do and simply requires a drill. I bought my SC lid from Toni too!
Back to top
User is offline
kaiowas
1985 Toyota MR2 Mk1a
PostPosted: Fri Mar 17, 2017 12:09 pm    Post subject: Reply with quote Reply with quote including images
When I was running a 4A-GZE in the sprint car I found it ran fine on the standard fuel system (n/a pump, factory SC fuel rail/regulator etc.), I also used an n/a engine lid (although the internal webbing had been removed for weight reduction)
Back to top
User is offline
Lauren
PostPosted: Fri Mar 17, 2017 12:45 pm    Post subject: Reply with quote Reply with quote including images
It runs fine but you won't make full power with a big pulley. I did have a later spec GZE mind but on the rollers it made 157bhp because of the fueling issue. Got it to 186bhp with an adjustable fuel pressure regulaotr.
Back to top
User is offline
SuperRedMR2
PostPosted: Fri Mar 17, 2017 2:22 pm    Post subject: Reply with quote Reply with quote including images
was that 157 rwhp?
Back to top
User is offline
Lauren
PostPosted: Fri Mar 17, 2017 6:51 pm    Post subject: Reply with quote Reply with quote including images
SuperRedMR2 wrote:
was that 157 rwhp?
Flywheel.
Think it was 126 at the wheels. I am trying to remember from 2002 though!
With a big pulley on an early engine 180bhp at the fly is the best you can hope for really.
Back to top
User is offline
SuperRedMR2
PostPosted: Sat Mar 18, 2017 11:06 pm    Post subject: Reply with quote Reply with quote including images
I collected the engine this morning.
Clocks say 102k kms so that's about 60k?
It's already got a big pulley on it so no need to buy one. I'll measure it tomorrow. It's got the air con compressor with it - can I remove this and run a different belt?
Also, was it standard for the intercooler to have a fan underneath it?
Back to top
User is offline
Lauren
PostPosted: Sun Mar 19, 2017 10:05 am    Post subject: Reply with quote Reply with quote including images
You can remove the aircon compressor, yes you will need a shorter belt.
It was not standard to have a fan under the intercooler and it's a crap modification in all honesty unless you are drag racing as above around 50mph it's more of a hinderance than a help.
Back to top
User is offline
SuperRedMR2
PostPosted: Sun Mar 19, 2017 4:54 pm    Post subject: Reply with quote Reply with quote including images
Something I forgot to ask, the exhaust manifold, is tubular standard?
Instead of fitting an adjustable FPR, will an APEXI SAFC work just as well? I can adjust the fuelling per 1000rpms?
Best regards,
Alex
Back to top
User is offline
Lauren
PostPosted: Mon Mar 20, 2017 6:18 am    Post subject: Reply with quote Reply with quote including images
The exhaust manifold is the same as an NA with an addition of an oxy sensor.
You need to adjust the fuel pressure, so if the Apexi can give more fuelling, maybe, but either way you'll still want to set it up on the rollers. If you've got an aftermarket manifold that's another reason to put it on the rolling road.
Back to top
User is offline
SuperRedMR2
PostPosted: Mon Mar 20, 2017 2:25 pm    Post subject: Reply with quote Reply with quote including images
Hi,
See attached photo of engine.
Definitely not the same as the N/A exhaust manifold then.
Back to top
User is offline
Lauren
PostPosted: Mon Mar 20, 2017 5:53 pm    Post subject: Reply with quote Reply with quote including images
Well, it's obviously an afermarket manifold, though not a pretty one!
Is there somewhere to put the oxygen sensor in that manifold or in the down pipe? Otherwise you'll need it cut into your exhaust system. I had to do this on mine.
Back to top
User is offline
SuperRedMR2
PostPosted: Mon Mar 20, 2017 7:31 pm    Post subject: Reply with quote Reply with quote including images
Yes there is a hole at the bottom for that.
I'll be taking it off and comparing the bottom flange to the standard N/A manifold to ensure my exhaust downpipe will fit, so while it's off, i'll spruce it up a bit.
Back to top
User is offline
SuperRedMR2
PostPosted: Wed Mar 22, 2017 9:42 am    Post subject: Reply with quote Reply with quote including images
How do I adjust the position of the alternator? I'm trying to get to the last exhaust manifold bolt and I cannot get to it as the alternator is in the way...
Back to top
User is offline
kaiowas
PostPosted: Wed Mar 22, 2017 12:26 pm    Post subject: Reply with quote Reply with quote including images
You don't. If the alternator is in the way you'll need to loosen the belt and remove it.
Belt tension is adjusted via the tensioner pulley (Loosening the bolt in the center of the pulley allows it to move, then the pulley position is adjusted using the bolt from underneath)
Supercharger belt tension is adjusted in the same way although the adjuster bolt is accessed from above.
Back to top
User is offline
SuperRedMR2
PostPosted: Wed Mar 22, 2017 12:32 pm    Post subject: Reply with quote Reply with quote including images
Oh ok.
I actually cut the alternator belt off, as it's connected to the air con compressor which is being removed.
I'll loosen that nut
Back to top
User is offline
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
