Alternator belt for a mk1 SC
Author Message
oukie
IMOC Organiser
1987 Toyota MR2 Mk1b
PostPosted: Tue Mar 07, 2017 5:48 pm    Post subject: Alternator belt for a mk1 SC Reply with quote Reply with quote including images
Hi does anyone know where I can get a new replacement belt for my SC with aircon, obviously there's Toyota, but with it being an import,
I wasn't sure of the availability, that and its a 15 mile drive to my nearest absoulty useless dealership.
I had a quick Google but only found belts for the n/a or the SC with NO aircon.
Chris
_________________
Mk1b White T-bar SC 1987, Mk1b White coupe Jan90, Mk1b White coupe Jan90 (spares), Mk1b Mica blue T-bar Mar90, Mk1b Mica blue T-bar,full climate control,Jan90, 5 mk1's [Smile]
Back to top
User is offline
jon_st205
PostPosted: Tue Mar 07, 2017 5:53 pm    Post subject: Reply with quote Reply with quote including images
I'll have a look at mine to see if the size markings are still legible.
Back to top
User is offline
Bear87
Premium Member
PostPosted: Tue Mar 07, 2017 7:02 pm    Post subject: Reply with quote Reply with quote including images
Try importcarparts.co.uk
Used them a couple of times always have the obscure parts.
Hope that helps
Brad
_________________
Smoke me a kipper. I'll be back for breakfast.
1992 Rev 2 Turbo Super Red
1991 Rev 1 N/A Steel Mist Grey (daily)
Back to top
User is offline
Lauren
PostPosted: Tue Mar 07, 2017 8:02 pm    Post subject: Reply with quote Reply with quote including images
You'll be able to get it from Toyota. Or try Toyota RRG Macclesfield. 01625 869 900. Ask for Paul, he'll be able to post it up to you.
_________________
2013 GT86 Injen Induction. Volks Racing TE37s & TRD Aero Fins, Mega sounds. TEIN Street Flex 5/6kg, TEIN EDFC Active Pro. Tuning Developments Remap 4-1 Manifold, TD resonated exhaust, decat/overpipe, AP Racing 4 Pot front brakes. [lover]
Back to top
User is offline
oukie
IMOC Organiser
PostPosted: Wed Mar 08, 2017 10:03 am    Post subject: Reply with quote Reply with quote including images
Thanks for the replies, I've got one coming from Fensport.
Back to top
User is offline
phaeton
Premium Member
PostPosted: Wed Mar 08, 2017 10:55 am    Post subject: Reply with quote Reply with quote including images
Surely you only need to know the length & number of ribs, a belt is a belt is a belt?
Back to top
User is offline
oukie
IMOC Organiser
PostPosted: Wed Mar 08, 2017 12:47 pm    Post subject: Reply with quote Reply with quote including images
The old belt was damaged, so was unreadable and I was unable to take a measurement for the same reasons.
I do have a modicum of intelligence.
For thanks for your 'input'
Back to top
User is offline
phaeton
Premium Member
PostPosted: Wed Mar 08, 2017 1:19 pm    Post subject: Reply with quote Reply with quote including images
Take it as sarcasm if you wish it wasn't intended so, but if it's still in one piece than all you had to do was fold it in half, measure top to bottom & double it, or get a piece of string & put it around the outside & again measure it. But as you have a modicum of intelligence you would already know that so I'll let you waste your money at Fensport when you could have gone to Eurocarparts.
Back to top
User is offline
jon_st205
PostPosted: Wed Mar 08, 2017 3:38 pm    Post subject: Reply with quote Reply with quote including images
Would be great to post up the size once you have received (and checked it fits) so it can be searched for by anyone in the future.
Cheers,
Jon
Back to top
User is offline
oukie
IMOC Organiser
PostPosted: Thu Mar 09, 2017 11:33 am    Post subject: Reply with quote Reply with quote including images
It's not joined any ore, part of the belt was potentially missing, also, seeing as I'd already removed the alternator, I was unable to run a length of string etc,
Back to top
User is offline
oukie
IMOC Organiser
PostPosted: Thu Mar 09, 2017 11:34 am    Post subject: Reply with quote Reply with quote including images
Cheers,
Jon
Will do.
Back to top
User is offline
jimi
1988 Toyota MR2 Mk1b
PostPosted: Wed Mar 22, 2017 3:34 am    Post subject: Re: Alternator belt for a no1 SC Reply with quote Reply with quote including images
[Eh?] I've never had any problem with Western Toyota at Halbeath
Back to top
User is offline
SuperRedMR2
1990 Toyota MR2 Mk1b
PostPosted: Wed Mar 22, 2017 12:33 pm    Post subject: Re: Alternator belt for a no1 SC Reply with quote Reply with quote including images
Chris
I've got a SC lump with the air con compressor, but i have just cut the belt off as i'll be removing the compressor. However, I can measure the belt for you if that helps?
Back to top
User is offline
oukie
IMOC Organiser
PostPosted: Sun May 14, 2017 10:21 am    Post subject: Re: Alternator belt for a no1 SC Reply with quote Reply with quote including images
That's because you have an n/a, Jimi, the young guy that came out to me from parts told me that Toyoyta did not make a mk1 supercharger.
Lololololololol
Back to top
User is offline
oukie
IMOC Organiser
PostPosted: Sun May 14, 2017 11:34 am    Post subject: Reply with quote Reply with quote including images
The belt that I used was a Gate's 5pk1030 12 from local factors
Back to top
User is offline
jimi
PostPosted: Sun May 14, 2017 4:26 pm    Post subject: Reply with quote Reply with quote including images
Hope you educated him [Very Happy] plus the really good parts guy (I think his name was Kirrill ?) has moved on [Sad]
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
