Started my car up last week (about tea time) and my power steering light came on. Thought to myself it will go off soon until I got to the roundabout at the end of my road. I wanted to turn right but ended up having to go straight on as it completely stopped working?!?
I checked the fluid level (which was fine) then thought it must be the belt snapped or slipped or something and I would check it once I got back home.
Got in to drive home and found it to be all fine again and I'm sure I wasn't dreaming
Does anyone know what could be wrong?
PAS stopped working!
- IMOC Affiliated Company
Re: PAS stopped working!
That old chesnut
Its just a relay playing up. If it happens again, rapidly twist the keys from off to ign on, about 20/30 times (until your arm aches). Pause a sec, turn the car back on and it should be fine. If not, try again, and again. It does work, usually first time.
HTH
Luke
HTH
Luke
Sounds familiar i had the same problem but the ignition trick didnt work.When i had it motd they informed me that i had excessive play in the steering rack so i bought a new one from rogue and it works perfectly
Man those MoTs were a nightmare! lol
Thinking, I'm gonna have probs MoT-ing mine, still got the 2 left headlights from a mk1!
Yeah its your relay....mine needs replacing too when ive got the time to be without my car and the cash, a pain but really gets my arms looking buff when its on the blink !!!
Yep, just keep turning that key. It does sound like the most stupid fix in the world, but it saved me a load of money.
It happened to me shortly after I got my 2 and it was looking for a likely reason for it failing that I first found the (original) imoc site.
Thanks IMOC!
Thanks IMOC!
ive had the same problem as well.. its a paint as it normally happens to my car after i leave it for a couple of days without use...!
Where can this relay be found?
