Ive decided to renew my exhaust manifold gasket so needing to remove the heat shield.
Im stuck with the 12mm heatshield bolt that is inbetween the turbo to manifold. It has rounded off. I cant get my irwin holt extractor on it. I csnt fit a smaller socket or spanner on it. It just wont undo.
I dont think i can get my grinder to it.
Any ideas?
I need to get that bolt out so i have better access to the exhaust manifold nut and stud as i cant get a 14mm socket on the exhaust manifold nut with it in the way.
[Mk2] [Turbo] Stuck heat shield bolt
Re: [Mk2] [Turbo] Stuck heat shield bolt
Can you get a hammer and chisel on it with the chisel side ways to split the nut or chisel flat to sheer the bolt head if its a bolt.
Once the manifold is off then you can drill and retap
This is next plan.
Gonna have to wait though as got an infection on my finger which has infected my whole hand
Alternatively hammer a socket on it and then undo, drop a size on a multipoint socket should go on fairly easily with some persuasion.
- Driftlimits Performance
- IMOC Affiliated Company
Leave it alone, there is no need to remove it. If you can't get on the 2 14mm nuts on the mani-head then just bend it a little until you can. It actually acts as a perfect guide for your socket and makes like easier imo.
Driftlimits Performance wrote:Leave it alone, there is no need to remove it. If you can't get on the 2 14mm nuts on the mani-head then just bend it a little until you can. It actually acts as a perfect guide for your socket and makes like easier imo.
Mmmm thanks. Will i need to remove the oil cooler?
