Mk1b motor into mk1a dash warning light issue!
Author Message
Speedy2020
PostPosted: Sat Feb 04, 2017 9:47 pm    Post subject: Mk1b motor into mk1a dash warning light issue! Reply with quote Reply with quote including images
Hi there after some advice as I have recently fitted a mi1b motor into my mk1a and it all runs perfect and have good oil pressure and voltage showing on the dash. The problem is when I turn the ignition key to position one I only get the brake warning light and ecu light on, both go off once started and hand brake off. I am from what I can gather missing the engine bay temp warning light and alternator warning lights on start up. Is there something simple I have missed or is it a more complex issue? Thanks in advance for any help.
Back to top
User is offline
PW@Woodsport
IMOC Affiliated Company
PostPosted: Mon Feb 06, 2017 7:18 am    Post subject: Reply with quote Reply with quote including images
Is it charging ok once running?
Check the alternator is plugged in, check the 5amp "charge" fuse.
_________________
Back to top
User is offline
Speedy2020
PostPosted: Thu Mar 09, 2017 8:02 pm    Post subject: Reply with quote Reply with quote including images
Was the fuse all along thanks 😀
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
