I've had this thrown in with the mr2 ive been given for free.
is it only worth installing this on a modified car? or will I be ok installing it on the stock car.
im unsure if its a full after market ecu or just a piggyback for more features.
Ross.
[Mk2] [Turbo] Greddy e-manage blue
Re: [Mk2] [Turbo] Greddy e-manage blue
just a piggyback fuel management ECU
if you have the full loom, the E-manage blue can also do ignition timing.
it's old tech, and basic but it works, you can still buy it brand new and it's still supported by GReddy.
http://www.greddy.com/tech-support/e-manage/
there's loads of info online but in short it does 16x16 fuel adjustment map, ignition timing control, allows use of larger injectors, boost limit (fuel cut) adjustment, basic datalogging etc..
it's not *that* far off what a power FC will do tbh, only for 1/4 of the cost
the E-manage ultimate is newer, and a lot better - better than the PFC imo
C35Rob wrote:if you have the full loom, the E-manage blue can also do ignition timing.
good for some basic power mods then. sounds ideal especially as it was thrown in with the car for free (also got the car for free)
In order to connect to it via a laptop you'll need a usb serial adapter like this
http://www.ebay.com.au/itm/USB-to-TTL-S ... SwZ8ZXCx5Z
then just put another USB A male end on it. There are various revisions of the software online along with firmware although some of the details are sketchy, I should have a load of bookmarks somewhere.
If you're on a budget you can use it as a electronic boost controller as well, it has a fuel map for a fifth injector (called something like that) and you can use it to operate a boost solenoid you just need to 'experiment' in order to determine what the duty cycle value in the fuel map actually equates to in terms of boost pressure.
tiff_lee wrote:In order to connect to it via a laptop you'll need a usb serial adapter like this
thank you. I've got a usb to serial cable lying around somewhere from my mx5 and megasquirt build.
I like the sound of electronic boost controller..... ideally would want switchable boost on switches in the dash. like you say, perhaps id have to engineer the 5th injector to act as a "High boost" function when a button is pressed/switch toggled.
Wouldn't be hard to use the 5th injector output for high boost only just wire the signal line via the switch to the solenoid but other then that you could only have a set duty cycle for a given rpm.
tiff_lee wrote:Wouldn't be hard to use the 5th injector output for high boost only just wire the signal line via the switch to the solenoid but other then that you could only have a set duty cycle for a given rpm.
looks like ive got a potential plan then cheers!
Like I said before i've not done it myself and I bought a profec EBC anyway but the functionality is there or so i've read. I have about a dozen bookmarks on the emanage blue I can send you there may be some useful stuff in there.
tiff_lee wrote:Like I said before i've not done it myself and I bought a profec EBC anyway but the functionality is there or so i've read. I have about a dozen bookmarks on the emanage blue I can send you there may be some useful stuff in there.
Sure would be great if you don't mind.
