Engine balancing
SuperRedMR2
Engine balancing
Post by SuperRedMR2 »
Hi all,
What components are required for complete engine balancing?
Does anyone ever balance the top end as well?
User avatar
Lauren
Re: Engine balancing
Post by Lauren »
The whole rotating assembly is balanced, which comprises, the flywheel, crank, rods and pistons.
You don't balance the top end, as there is no point in balancing camshafts.
aw11rally
Post by aw11rally »
Probably worth either balancing or replacing (with a lighter one) the crank pulley while you're at it.
SuperRedMR2
I've had a lightened one before, didn't do me any favours and it was missing the harmonic balancer.
Going to stick to the standard crank pulley.
aw11rally
Post by aw11rally »
Do you want to sell the alloy one?
What problems did it cause?
boondougal
Post by boondougal »
SuperRedMR2 wrote:I've had a lightened one before, didn't do me any favours and it was missing the harmonic balancer.
I have one of these alloy ones on my engine, i have a sneaky suspicion that once the car is actually on the road this pulley will be more trouble than its worth.
SuperRedMR2
For starters when my cambelt snapped, I couldn't get it off.
The key slot wasn't particularly strong either.
It had basically melted to the end of the crank. It came off via a chisel which in turn damaged the end of my crank which I had to have sleeved.
It went in the bin ages ago. I thought it was a bargain for £75 with the alternator pulley, PAS AE86 pulley, water pump pulley and the crank. No, no it was not.
rev2rich
Post by rev2rich »
jimi
Post by jimi »
:roll:
Not much use for a 4A-GE :wink:
gon
Post by gon »
you can (and should) also balance the clutch plate with the engine ...
Balance it without and then with .... on the second pass (with) material removal should only take place in the clutch plate
SuperRedMR2
gon wrote:you can (and should) also balance the clutch plate with the engine ...
I was going to do the clutch assembly as well :thumleft:
