[Mk2] [Turbo] MR2 KM2 Rev 1 Turbo: 19 mpg standard?
doctor_tom
Post by doctor_tom »
HI,
I have a MR2 MK2 Rev 1 Turbo with uprated inter-cooler, intake, 3" decat and huge exhaust, 1 bar boost.
The car is sound, no fault codes, runs like a dream... but I only get around 18-20 mpg no matter how I drive it, it is usually driven off boost as if I gun it I can visibly see the fuel gauge go down.
Is this normal?
Anything I can check?
Pauln
Re: [Mk2] [Turbo] MR2 KM2 Rev 1 Turbo: 19 mpg standard?
Post by Pauln »
Sounds a bit low if you're being gentle with the right boot. I certainly average a bit better than that with my rev2. Have you checked he colour of the plugs for any signs of over fueling?
Paul
androo007
Post by androo007 »
I hit 29-30mpg usually when my Rev 3 was the same spec.
doctor_tom
Hi,
I'll check the plugs, might get a AFR meter but I know it is over fueling just trying to work out why.
Maybe the lambda sensor is shot. I did redo the wire to the lambda sensor as it had melted which may not be sensible but I think it just gives a voltage but this may have changed the resistance in the wire.
No ECU faults as I said... AFM working fine... Water temp sensor rewired.
SonicSW20
Post by SonicSW20 »
Have you tested the ECU water temp sensor and the o2 sensor?
doctor_tom
I have not. I just redid the wiring the connectors.
Is there a method?
SonicSW20
Post by SonicSW20 »
Yes, check the BGB - https://drive.google.com/open?id=0B-dpU ... jJTcE1BNTQ
there's a reference chart of resistance vs temperature for the ECU temp sensor - it's just a thermistor.
There's also a troubleshooting section that lists the common causes of poor fuel consumption.
doctor_tom
Gazza_DJ wrote:Yes, check the BGB - https://drive.google.com/open?id=0B-dpU ... jJTcE1BNTQ
HI mate,
thanks for that link, very useful!
I'll check the water temp and O2 sensor and clean the air filter.
