[Mk2] [Turbo] Using an SRT205 ECU - No Powersteering output
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical
Author Message
Danbob
PostPosted: Tue Oct 18, 2016 9:07 pm    Post subject: [Mk2] [Turbo] Using an SRT205 ECU - No Powersteering output Reply with quote Reply with quote including images
I'm running a rev3 conversion into a Rev 2 turbo.
As far as I know the ECU I have is from an ST205
Am I right in thinking that the ST205 ECU will not have PSCT and PS pins?
Therefore I will only be able to have PS running permanently, without a speed or idle cut, and won't get any PS idle up?
If so, I'll be wanting a SW20 one
Dan
Back to top
User is offline
markstevieandmads
PostPosted: Wed Oct 19, 2016 7:20 am    Post subject: Reply with quote Reply with quote including images
Im sure shinny is running a st205 ecu for his cc system. Best to ask him.
Back to top
User is offline
Danbob
PostPosted: Wed Oct 19, 2016 8:34 pm    Post subject: Reply with quote Reply with quote including images
Will do cheers
Back to top
User is offline
outrun
Premium Member
PostPosted: Wed Oct 19, 2016 10:33 pm    Post subject: Reply with quote Reply with quote including images
Just converted my own Rev 2 Turbo to a Rev 3.
I cut the PSCS wire on the car loom and the steering works fine.
Back to top
User is offline
Danbob
PostPosted: Thu Oct 20, 2016 5:10 am    Post subject: Reply with quote Reply with quote including images
Hi, yeah ive removed the psct pin and the ps runs, but is there no problem to let it run all the time without having the ecu cut?
Back to top
User is offline
shinny
PostPosted: Thu Oct 20, 2016 10:31 am    Post subject: Reply with quote Reply with quote including images
Dan PMed me... for the record, this was (part-of) my response:
To get your PS pump to actually run, you need to cut the wires that allow the ECU to switch off the PS, as the ST205 doesn't have those outputs. That does mean my PS pump is active even when the engine isn't running... which was really useful when I needed a tow from the RAC! The PS also switches off at high speed (>50mph) - this is handled by the PS ECU in the frunk and not the engine ECU in the boot. (They receive the speed signal independently) I did not notice a change in this high speed behaviour when I converted my ECU.
I've not really found the slightly changed behaviour is a problem, however I was thinking the other day that connecting the enable wiring the enable wire to an oil pressure switch would provide a nice approximation to the stock behaviour. Not really worth the effort to sort that out though.
Back to top
User is offline
markstevieandmads
PostPosted: Thu Oct 20, 2016 4:12 pm    Post subject: Reply with quote Reply with quote including images
Pmd bout this as interested in doing this.
Back to top
User is offline
outrun
Premium Member
PostPosted: Thu Oct 20, 2016 4:51 pm    Post subject: Reply with quote Reply with quote including images
I left PS connected, cut PSCS and my steering cuts in and out and comes on with ignition like it always has. As above, the ECU for it is in the frunk.
Back to top
User is offline
Danbob
PostPosted: Thu Oct 20, 2016 7:08 pm    Post subject: Reply with quote Reply with quote including images
So what is the purpose of the PSCT pin then?
Back to top
User is offline
outrun
Premium Member
PostPosted: Thu Oct 20, 2016 8:23 pm    Post subject: Reply with quote Reply with quote including images
I meant PSCT, not PSCS.
Will have to check notes, but I am sure that PSCT keeps the steering on when the engine is running. PS is the signal to power the steering when the ignition is turned on.
Back to top
User is offline
jon
Premium Member
PostPosted: Thu Oct 20, 2016 8:26 pm    Post subject: Reply with quote Reply with quote including images
The ECU pulls PSCT to ground to disable the power steering. I have a ST205 ECU so I can't test, but from memory it does that when starting to reduce the load on the battery.
Back to top
User is offline
Danbob
PostPosted: Fri Oct 21, 2016 5:24 am    Post subject: Reply with quote Reply with quote including images
So from what I can gather from response, the answer to the question is....
The st205 ecu does not have any provision for mr2 power steering. You will lose the idle up (ps pin) and the powersteering cut when engine is not running.
But - power steering will still cut at motorway speeds as intended and people are running without both without finding any problems.
Back to top
User is offline
shinny
PostPosted: Fri Oct 21, 2016 4:10 pm    Post subject: Reply with quote Reply with quote including images
My post in Toxo's thread on the subject: http://www.imoc.co.uk/forums/viewtopic.php?p=1393030#1393030
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical All times are GMT
Page 1 of 1
Jump to:
