[Mk2] [Generic] Running cables from engine bay into cab
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical
Author Message
tiff_lee
PostPosted: Sat Sep 10, 2016 5:59 pm    Post subject: [Mk2] [Generic] Running cables from engine bay into cab Reply with quote Reply with quote including images
I have about half a dozen cables I need to run from the engine bay into the cab (small stuff sensor wires etc), just wondering if there are any goto existing grommets everyone uses so I have a heads up before I start poking around.
Back to top
User is offline
C35Rob
Premium Member
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Sat Sep 10, 2016 7:17 pm    Post subject: Reply with quote Reply with quote including images
yeah mate, either side of the car on the rear bulkhead there are grommets where existing wiring goes through
you can see one of them there - the hole in the gold heat tape, the other one is in the same place on the other side, under the raised patch that hasn't been poked through yet.
_________________
Back to top
User is offline
tiff_lee
PostPosted: Sun Sep 11, 2016 5:24 am    Post subject: Reply with quote Reply with quote including images
Awesome cheers Rob
Back to top
User is offline
tiff_lee
PostPosted: Fri Sep 30, 2016 7:04 am    Post subject: Reply with quote Reply with quote including images
Finally got all these cables routed through the spare hole on the drivers side
Got some ally sheet laying around so i'll probably just bolt a plate onto a couple of nearby mounting points then attach the greddy profec control unit and solenoid to said sheet. The profec cabling makes it about a third of the way along the centre console so going to extend the loom up to the dash.
just a query on those reference pictures above, I assume all that gold reflective tape is to replace the OE stuff? mine was just crumbling to dust as soon as I disturbed it, if it wasn't for the heat shields going back on it would look a right state.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical All times are GMT
Page 1 of 1
Jump to:
