[Mk2] [Generic] Rev5 NA - Turbo Conversion - Immobiliser
SonicSW20
Post by SonicSW20 »
Getting closer to a Gen3 Turbo swap on my Rev5 :D
At the moment, it just has the stock immobiliser and alarm, both of which work fine. Ideally I'd like to keep as much of the stock stuff as possible. I can keep the stock remote locking, I'm pretty sure I can keep the stock alarm too. I can't keep the stock immobiliser though as far as I am aware as that interacts with the NA ECU, and won't work with the Gen3 Turbo ECU.
So, I need to get an aftermarket immobiliser. I know nothing about them.
I don't want one of those stupid electronic contact ones.
I would prefer it to be invisible, so the transponder needs to be hidden behind the dash panel ideally. If there's a way I can integrate it into a Toyota key like the OE one, that would be amazing, but not essential.
What are my options for an aftermarket immobiliser?
thomp1983
Re: [Mk2] [Generic] Rev5 NA - Turbo Conversion - Immobiliser
Post by thomp1983 »
You're pretty much out of luck mate, nearly all standalone cat 2 immobilisers use either a contact fob or a remote fob neither of which you can integrate with the Toyota fob.
Your best bet would be to fit a complete new alarm really and do away with all the oem stuff
SonicSW20
Post by SonicSW20 »
Integrating into a Toyota key isn't a must have.
http://www.ebay.co.uk/itm/TOAD-STERLING ... 0623138114
This seems to be the only option - don't know if they are any good though?
I don't want an aftermarket alarm unless I absolutely have to.
thomp1983
Post by thomp1983 »
Toad are up there with the best, the kit is reliable nearly all issues with them are from poor installation
Return to “ICE and Security”
