[Mk2] [Turbo] If I was an electrician, where would I put MPH converter
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical
Author Message
DottySkee
PostPosted: Fri Aug 12, 2016 1:25 pm    Post subject: [Mk2] [Turbo] If I was an electrician, where would I put MPH converter Reply with quote Reply with quote including images
Hi all
I've been absent from the forum for a looong time now and the MR2 has sat outside looking rather neglected, untouched for a year. Money issues and the long battle to get the Rev 3 engine working in a rev 2 body (which is still unsuccessful but an issue for another thread) meant I lost a lot of love for Mr 2.
I've started tinkering away again though on all the other jobs that need done even before the problem of the engine is dealt with before my old man gets back from work in 4 weeks and we have to bell through every wire to find our mistake.
Managed to get a hold of a stefs delimiter from another forum member last year and finally got round to taking the dash apart and fitting. I had fully expected to see another converter on the back of the clocks I would remove and fit the stefs. There wasn't though...
So my question is, where else are the common places to wire in a mph converter? Obviously it needs whipped out, but from where. Any ideas on the usual places?
Back to top
User is offline
thomp1983
PostPosted: Fri Aug 12, 2016 2:32 pm    Post subject: Reply with quote Reply with quote including images
Only other place would be at the ecru, are you sure no ones fitted a uk speedometer in your cluster?
Back to top
User is offline
raptor95GTS
PostPosted: Mon Sep 05, 2016 10:46 pm    Post subject: Reply with quote Reply with quote including images
gearbox feed goes straight to the dash, from the dash to the ECU.
Back to top
User is offline
EvilPanda
1990 Toyota MR2
PostPosted: Tue Sep 13, 2016 7:53 pm    Post subject: Re: [Mk2] [Turbo] If I was an electrician, where would I put MPH converter Reply with quote Reply with quote including images
Thanks[/quote]
I just done mine. Wired straight on the speed sensor. Looks like it works for me. Might be the odometer is still counting in km but who gives a damn. Clock it back in 10mins and u good to go...
Back to top
User is offline
DottySkee
PostPosted: Fri Oct 07, 2016 12:17 pm    Post subject: Reply with quote Reply with quote including images
It's Jap clocks for sure, complete with small bit of black tape to cover the k on km/h [Laughing]
Thanks for the tips, I'll have a hunt around the speed sensor for it, probably the most likely as I've checked the ECU and it's as normal.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical All times are GMT
Page 1 of 1
Jump to:
