[Mk2] [Turbo] Clock-->boost gauge?
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical
Author Message
MR2Kyle
1999 Toyota MR2 Mk2 NA Rev5
PostPosted: Sat Aug 06, 2016 7:07 pm    Post subject: [Mk2] [Turbo] Clock-->boost gauge? Reply with quote Reply with quote including images
Hey folks,
I like to keep my car as standard looking as I can and one thing I was thinking was is there any way you could set up the clock so it not only reads the time but can also be switched to display a digital boost gauge? Could hardly buy a boost gauge and just use the circuit from it and modify the clock in some way to switch between the two displays? I know this seems a bit extreme but the car was a na so the dash is staying and I don't want anything obvious sticking out of the dash.....if anyone has any ideas or can help me fire away [thumleft]
Back to top
User is offline
abovetherim
1991 Toyota MR2 Mk2 NA Rev1
PostPosted: Mon Aug 08, 2016 6:50 pm    Post subject: Reply with quote Reply with quote including images
Surely it would be much easier to put a boost gauge in the speedo cluster. Just put it where the voltmeter is just like the OE position for the boost on/off indicator (not really an accurate boost gauge by all accounts).
Back to top
User is offline
C35Rob
Premium Member
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Tue Aug 09, 2016 10:38 am    Post subject: Reply with quote Reply with quote including images
Everything is possible if you put enough time/effort/money into it
You would need something like an arduino board, map sensor, an lcd display that will fit in place of the original clock screen, some basic electronics/code knowledge or the drive to learn
So yeah, totally possible, but something you'd have to do yourself, there isn't an off the shelf 'mr2 boost gauge clock' plug and play kit
_________________
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Tue Aug 09, 2016 10:46 am    Post subject: Reply with quote Reply with quote including images
http://cstark27.blogspot.co.uk/
There are quite a few examples available online complete with example code and lists of components used. Would be an interesting project.
Back to top
User is offline
C35Rob
Premium Member
PostPosted: Tue Aug 09, 2016 10:55 am    Post subject: Reply with quote Reply with quote including images
Perfect example, given the potential of the arduino boards (check out the speeduino ECU for example) it'd be pretty cool to knock up a Din sized readout (or even feed the info to a double din lcd screen) that could do boost, oil temp and press, water temp, peak hold and warning on all of the parameters, you could even have it control boost, etc etc, the possibilities are literally endless [thumleft]
Back to top
User is offline
tiff_lee
PostPosted: Tue Aug 09, 2016 1:46 pm    Post subject: Reply with quote Reply with quote including images
Awesome, the amount of things that people use Arduino's for never ceases to amaze me.
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Tue Aug 09, 2016 2:06 pm    Post subject: Reply with quote Reply with quote including images
There are some projects to build ECU's using Arduino's - http://speeduino.com/wiki/index.php/Overview
Back to top
User is offline
C35Rob
Premium Member
PostPosted: Tue Aug 09, 2016 2:56 pm    Post subject: Reply with quote Reply with quote including images
This is going off topic now, but I'm certain someone with more time on their hands than me could create a standalone knock control system with an arduino. There's already an arduino knock detector (guides online) there must be a relatively simple way to get it to intercept the ECU (I.e power FC) IGN signal and retard IGN if 'real' knock is seen
The power FC has already been cracked/decoded (Datalogit/FChako) so it's clearly possible - imagine how popular an add-on box to give the PFC knock control and some decent I/O would be.
Imagine a piggyback box for a couple of hundred pounds that would give your PFC knock control, w/m control, USB stick datalogging, launch, anti lag etc - it'd literally fly off the imaginary shelves.
Back to top
User is offline
tiff_lee
PostPosted: Tue Aug 09, 2016 5:25 pm    Post subject: Reply with quote Reply with quote including images
On a similar note you could do all this with an android head unit/tablet setup.
Or a more plug and play solution is to use a Toyobd1
https://www.facebook.com/groups/1505898572959292/
unfortunately it has snags connecting to my Eonon android head unit ><
Back to top
User is offline
2mad
Premium Member
1990 Toyota MR2 Mk2 Turbo Rev1
PostPosted: Tue Aug 09, 2016 6:00 pm    Post subject: Reply with quote Reply with quote including images
Wow hell yeah .. i would have bought that like a shot [thumleft]
Back to top
User is offline
jon
Premium Member
PostPosted: Tue Aug 09, 2016 6:12 pm    Post subject: Reply with quote Reply with quote including images
There was a multi function display made by Dynosty in the US that replaced the standard clock.
https://www.youtube.com/watch?v=G6wfjccHXOg
They don't make them anymore, but they did say they'd consider making another batch if 10 people pay upfront.
http://www.mr2oc.com/32-mr2oc-authorized-vendor-group-buy-sales/440684-dynosty-clock-multi-function-display-e85-boost-temp-pressure-f-volt.html
Back to top
User is offline
C35Rob
Premium Member
PostPosted: Tue Aug 09, 2016 10:37 pm    Post subject: Reply with quote Reply with quote including images
Jon,
you're the guy that developed the daughter board for the stock ECU aren't you?
what do you think of the feasibility of using an Arduino (or similar?) to add functionality to the PFC? primarily USB datalogging and knock control?
Back to top
User is offline
jon
Premium Member
PostPosted: Wed Aug 10, 2016 9:46 am    Post subject: Reply with quote Reply with quote including images
Yep, thats me.
I don't think the standard Arduino is powerful enough to handle knock control. You do know control you need to be sampling the knock sensor signal at 15Khz as a minimum. The data then needs to be cleaned up, filtered and interpreted. Doing all that on a 20Mhz 8-bit Microcontroller is pushing it a bit.
Something like the Arduino Due would be more suitable with it's Cortex M3 MCU. It is 32-bit, runs at 84Mhz and has high-speed USB.
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Wed Aug 10, 2016 10:01 am    Post subject: Reply with quote Reply with quote including images
What about a Raspberry Pi?
Back to top
User is offline
jon
Premium Member
PostPosted: Wed Aug 10, 2016 10:50 am    Post subject: Reply with quote Reply with quote including images
It would be quite hard to get sub microsecond accuracy on ignition timing on something that's running an OS. Removing the OS and programming the board bare metal would be a massive undertaking, especially since Broadcom haven't AFAIK released all the chip documentation.
Also the chip is in a BGA package which isn't automotive friendly. The board takes a lot of power which makes building an automotive quality power supply for it harder.
Probably great for displaying info in the car, but I wouldn't want it controlling the ignition timing!
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical All times are GMT
Page 1 of 1
Jump to:
