knock sensor
Author Message
autobody
Premium Member
1988 Toyota MR2 Mk1 SC
PostPosted: Wed Aug 03, 2016 9:29 am    Post subject: knock sensor Reply with quote Reply with quote including images
Question for the SC owners - is there any other knock sensor that will work with the 4agze?
I am getting a error code 52 and I am unable to find a replacement, I have contacted Toyota and been told its discontinued, this is the part number I have 89615-17010.
I think it may be a case of holding out for a used one but I would be interested to know what others have done.
p.s. if you do have a spare knock sensor I will be happy to buy it. [thumleft]
Back to top
User is offline
kaiowas
1985 Toyota MR2 Mk1a
PostPosted: Wed Aug 03, 2016 10:05 am    Post subject: Reply with quote Reply with quote including images
TCB sell various knock sensors for Toyotas, I'm pretty sure one of them will be the right one although none of them are listed for the 4A-GZE
Think it might be the QIC 916 although it's probably best to give them a call and check rather than ordering one blindly.
Back to top
User is offline
autobody
Premium Member
PostPosted: Wed Aug 03, 2016 10:56 am    Post subject: Reply with quote Reply with quote including images
Thanks, just given tcb a call and are currently checking if it fits.
Back to top
User is offline
autobody
Premium Member
PostPosted: Thu Aug 11, 2016 7:59 pm    Post subject: Reply with quote Reply with quote including images
TCB have said the QIC 916 knock sensor will not work as it has different frequency readings. They don't stock 4agze knock sensors.
But I have now got a second hand unit. (Hope it works) I am going to temp to fit this in on Sunday.
Can I ask if other have done this job what was required? Is it accessable under the car? Do I need to remove any items to get to the knock sensor. Any tips appreciated. [thumleft]
Back to top
User is offline
kaiowas
PostPosted: Fri Aug 12, 2016 9:56 am    Post subject: Reply with quote Reply with quote including images
From memory it should be easy enough and accessible from underneath without removing anything although some contortion may be required, you should certainly be able to get the socket on, I just can remember how easy it is to find enough space to swing a ratchet. Oh and make sure you have a deep socket of the appropriate size, a standard socket won't cut it.
Also take care with the wiring/connector when unplugging the old one. Not sure if I've just been unlucky but all the GZE looms I've had have been particularly fragile in this area.
Back to top
User is offline
autobody
Premium Member
PostPosted: Sat Aug 13, 2016 10:36 pm    Post subject: Reply with quote Reply with quote including images
Update: replacment knock sensor fitted and looks to have done the trick. I have a small coolent leak at the front so only took the car behind my house. Drives much much better and no engine light.
To confirm, 27mm deep socket used and a small extension. Found I had just about enough room.
Thanks for your help kaiowas [thumleft]
Back to top
User is offline
autobody
Premium Member
PostPosted: Sat Aug 13, 2016 10:41 pm    Post subject: Reply with quote Reply with quote including images
Here is a pic of the knock sensor.
Both had Toyota markings on them. The top one came off the car and the bottom one was a replacement. Look similar but the bottom one was longer slightly.
Back to top
User is offline
jayelem
1989 Toyota MR2 Mk1 SC
PostPosted: Fri Apr 28, 2017 12:17 am    Post subject: Reply with quote Reply with quote including images
could do with one myself!
Back to top
User is offline
jon_st205
PostPosted: Fri Apr 28, 2017 4:06 pm    Post subject: Reply with quote Reply with quote including images
Let me dig around, I'm sure I have one somewhere.
Back to top
User is offline
jayelem
PostPosted: Sat Apr 29, 2017 2:45 pm    Post subject: Reply with quote Reply with quote including images
ive even crossed my balls in hope!
Back to top
User is offline
jayelem
PostPosted: Mon May 01, 2017 12:34 am    Post subject: Reply with quote Reply with quote including images
Bank holiday bump!
Back to top
User is offline
SuperRedMR2
1990 Toyota MR2 Mk1b
PostPosted: Mon Dec 11, 2017 3:22 pm    Post subject: Reply with quote Reply with quote including images
Has anyone else got a spare?
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
