Hi Guys
Wanting to remove the AC system in my Turbo,
has anyone recently done this and can give me a little step by step,
and whats actually needed to be taken out ?
thanks,
Jordan.
[Mk2] [Turbo] AC Removal
Re: [Mk2] [Turbo] AC Removal
Not much to removing the ac pump 4bolt hold it on remove the belt and take the 2 hose lines off with big spanner
Depends how much you want to remove.
There is the dryer and condenser at the front, the mini-rad behind the dash, the alu pipes, the control in the dash and then the pump with mount.
You'll need the non air con plastic to replace the mini-rad under the dash and the non-AC controls to tidy up the dash.
Just don't forget to short out the connector in frunk or you rad fans will be on constantly
