[Mk2] [Turbo] Turbo Options
mr2nut123
Post by mr2nut123 »
If you wanted to just pop over the 300hp mark and run less boost, is there a turbo that's slightly more efficient than a CT20, but still remains on stock ECU without needing a remap? Perhaps rebuilding a CT20 is an option?
I don't want to go down the forged route again this time.
Re: [Mk2] [Turbo] Turbo Options
Post by Martin F »
I ran a TD05 on standard set up, ran fine, it was stronger than ct20b for sure, wouldn't like to estimate what power it was putting down at what boost but here is a video of it at 1-1.1 bar
I sold it to sheppy, he then sold it to another member, maybe worth tracking the buyer down because they may not have used it, would be a cracking purchase for you.
clutch was slipping unfortunately, but you get the idea :thumleft:
https://www.youtube.com/watch?v=7x9PDbR_a_I
2barGee
Post by 2barGee »
mr2nut123 wrote:If you wanted to just pop over the 300hp mark and run less boost, is there a turbo that's slightly more efficient than a CT20, but still remains on stock ECU without needing a remap? Perhaps rebuilding a CT20 is an option?
A CT20 will do 300bhp easy just stick with that, no point spending loads of money on a bigger turbo and not run anymore power from it. Especially if you don't want to go forged.
Spend the money on better brakes and tyres and go even faster.
8)
Al-sw20
Post by Al-sw20 »
The ct20b is the best stock fuel system turbo.
mr2nut123
Post by mr2nut123 »
Martin F wrote:I ran a TD05 on standard set up, ran fine, it was stronger than ct20b for sure, wouldn't like to estimate what power it was putting down at what boost but here is a video of it at 1-1.1 bar
Cheers Martin. I'll have a look into that :thumleft:
androo007
Post by androo007 »
I have a TD06 20G on at the moment with wastegate pressure. I've heard they are good to around 14psi. But thats no use really as they don't get into their zone until 20psi.
Which leads to the next question....
The stock ECU will bang out a CT20 @ 300bhp / 1.2 bar no problem.
Why change? The jump up is RATHER large in cost.
Post by Martin F »
2mad was the buyer of that turbo, send him a pm to see what he did with it... :thumleft:
Milo_101
Post by Milo_101 »
Keep boosting the ct20b until it spits it's guts out. It makes 300 crank hp easily. After that rebuilt it with billet wheels, and be capable of pushing well over 300whp.
mr2nut123
Post by mr2nut123 »
Milo_101 wrote:Keep boosting the ct20b until it spits it's guts out. It makes 300 crank hp easily. After that rebuilt it with billet wheels, and be capable of pushing well over 300whp.
I think that's what I'll do to be honest. I like the response from it too. Thanks for all the tips guys..
When you say rebuild with billet wheels, how much is this and is there a favoured place to get it done? What kind of cost?
Race Idiot
Post by Race Idiot »
Don't think there's anyone in the UK that does a billet CT20. There are some options in the us but they want a CT20 core which is a bit much to ship a broken turbo across the sea.
I've got an old HKS TD05-16 with a billet wheel from owens, not massive power but it spools fast and kicks harder than a ct20. Wouldn't recommend, but I got the turbo kit for cheap and it has a similar compressor map as a gt28. Was more interested in fast spoolup than power anyway.
MR2Kyle
Post by MR2Kyle »
What's the ct15b like? Sorry for hijacking the tread a little but I was just wondering what's it's capable of and how reliable it is overall? :mrgreen:
Mk1b 1989 Mica Blue
Mk2 rev3 1993 NA Turquoise
Mk2 rev5 1999 Cosmos Blue with st215 conversion 😉
Al-sw20
Post by Al-sw20 »
Not worth the cost to get it to work. It's a single entry turbo.
User avatar
JAAASH
Post by JAAASH »
I'm currently selling my old gt28 setup that I ran on standard fuelling and injectors.
Made 343bhp on that setup and it felt mega.
Link here if you're interested - http://www.imoc.co.uk/forums/viewtopic.php?t=190609
_________________
"What the Deuce?!"
My MR2 - http://www.imoc.co.uk/forums/viewtopic.php?t=174494
sky-net
Post by sky-net »
Race Idiot wrote:Don't think there's anyone in the UK that does a billet CT20. There are some options in the us but they want a CT20 core which is a bit much to ship a broken turbo across the sea.
I've seen a CT20b with a choice of different stages or specs being sold at mr2-ben today for the first time.
jimGTS
Post by jimGTS »
ats ct21 is an option, but probably looking at 1k all in id say to get it over here.
plus they need your old turbo.
stock 20bs are pretty decent on track and drag.
get tuning right and you will surprise plenty of cars!
:mrgreen:
mr2nut123
Post by mr2nut123 »
That's pretty interesting. I remember only a month or so back, someone said that nobody in the UK does billet conversions on CT20s. Would they bolt right on with stock ECU too?
jimGTS
Post by jimGTS »
you would want to keep an eye on AFRs if fitting a turbo larger than stock.
factor in a wideband gauge imo.
id be interested to here/see of anyone using one of the ones supplied by mr2ben
it is obviously out sourced work, would like to know by whom.
mr2nut123
Post by mr2nut123 »
I need a third gauge for my Stack pod actually. Maybe I should get a wideband in anyway. Where do they need to be connected Jim?
jimGTS
Post by jimGTS »
It's a gauge and separate o2 sensor.
Assuming you have a downpipe you should have a spare port to fit the sensor at the bottom of it.
It needs to read afrs about 2-3foot from the turbo.
Handy, all the aftermarket downpipes have this bung welded in.
Unless of course you have a blitz downpipe and you may not be so lucky.
mr2nut123
Post by mr2nut123 »
jimGTS wrote:It's a gauge and separate o2 sensor.
LOL typical, I think that's exactly what I've got. I might just stick a voltmeter gauge on to fill the gap :)
