[Mk2] [Turbo] Squeaky / Creaking noise from clutch ... F**king annoying !
JLW
Post by JLW »
Hi Guys
So I've put up with this noise pretty much since I bought the car last year,
Pacific Works oiled up the clutch arm twice and it hasn't seemed to do anything, doesn't happen all the time.
predominately when the cars cold, and dry / hot weather outside.
nothing wrong with the clutch just the noise that could make you want to test out flight of beahy head !
anyone had this noise before and rectified it ?
http://vid1252.photobucket.com/albums/h ... gdhcev.mp4
thanks,
jordan.
SonicSW20
Re: [Mk2] [Turbo] Squeaky / Creaking noise from clutch ... F**king annoying !
Post by SonicSW20 »
Mine used to do it, and hasn't done it since I changed the clutch and greased all metal on metal contact points. Thing is since the clutch, pressure plate, and release bearing were all changed I couldn't tell you which one was making the noise!
JLW
Post by JLW »
This is what I feared TBH, the noise seems to disappear when the cars hot, which lead me to believe its something internal in the clutch housing.
Guess ill have to put up with it until I need a new clutch :(
gnzyza
Post by gnzyza »
Unfortunately its the clutch release fork. There is a rubber boot you can spray grease into being careful not to get it on other things. I did this and it helps but comes back after a while.
When I fitted my new clutch I made sure to clean everything properly and polish the ball pivot to a mirror shine and grease all contact points. Been fine since :thumleft:
JLW
Post by JLW »
gnzyza wrote:Unfortunately its the clutch release fork. There is a rubber boot you can spray grease into being careful not to get it on other things. I did this and it helps but comes back after a while.
Hi Mate,
Any specific type of grease that I could use to help do this until I have to fit a new clutch ?
Ill make sure that everything is polished and greased when the clutch is done !
SonicSW20
Post by SonicSW20 »
I wouldn't be too keen on spraying anything down there tbh, definitely don't want anything like that getting on your clutch or flywheel! Any aerosol grease is going to be quite thin as well.
gnzyza
Post by gnzyza »
I used white lithium grease (not ideal) maybe a moly spray grease would be better. If you aim it right and only squirt a little you shouldn't get it where it not supposed to. But it's not ideal, and may make the squeek worse once it comes back.
markstevieandmads
Post by markstevieandmads »
Mine does this too but only sometimes...also not as loud.
JLW
Post by JLW »
So the general consensus is leave it and then tackle the issue when I have to change the clutch ?
I wouldn't mind getting some Viscous grease and keep on top of keeping the fork lubricated,
but I also dont want to risk getting any on vital parts. ?
Rob66
Post by Rob66 »
Mine sometimes does this too, flipping annoying, I went and got some lithium grease but nervous about spraying it in the wrong place, even considered changing the clutch just to get rid of it :(
At the moment keep fingers crossed every time I start the car hoping it's having a quiet day lol..
JLW
Post by JLW »
Rob66 wrote:Mine sometimes does this too, flipping annoying, I went and got some lithium grease but nervous about spraying it in the wrong place, even considered changing the clutch just to get rid of it :(
yeah to be honest I'm not to keen on spraying lubricant on there now people have mentioned that it could land on the flywheel and clutch itself !
I know the feeling mate, do you notice that the sound kind of reduces when the car gets hot ?
Also thought about changing the clutch just to get rid of the noise, probably will in the near future to be honest !
Rob66
Post by Rob66 »
Hi mate,
Mine seems pretty random I thought it was damp that caused it, but last Sunday dry and hot and it was back. Amazing how much it affects my enjoyment of the car. If I find a way of solving it I'll let you know.
Rob
Rob66
Post by Rob66 »
Cheers for info, mine still has the original clutch (on101k). think I will get on the phone to TCB this week and get a replacement the Exedy £78.50 plus VAT looks like the one.
So it's the ball pivot that needs to be polished and greased? :wink: any other tips so I can give the local independent garage I use clear instructions - who are really good to be fair.
SonicSW20
Post by SonicSW20 »
Rob, try Ade Glover (MR2Bitz) for an Exedy OE replacement clutch for an NA. Was a fair bit cheaper than that a few months ago!
Yes, you need to grease all metal on metal contact points. The BGB shows you everything you need to grease.
Rob66
Post by Rob66 »
Cheers Gazza will do :thumleft:
raptor95GTS
Post by raptor95GTS »
i have the same squeak, I just ignore it :thumleft: :mrgreen:
JLW
Post by JLW »
raptor95GTS wrote:i have the same squeak, I just ignore it :thumleft: :mrgreen:
there is no ignoring this noise on my side, its more annoying then a fart in a spacesuit !!
alanmr2turbo
Post by alanmr2turbo »
japspeed exhaust twined with 2 x 12" subwoofers and i tend not to hear little squeaks :lol:
JLW
Post by JLW »
mate , Blitz nur spec with Berk de-cat !
Rob66
Post by Rob66 »
Hi Jordan
Did you ever sort out your squeaky clutch? Mine has decided to return last few days :(
Cheers mate
