just wandering if anyone has any ideas as to why im getting fuel cut at different pressures? i was under the impression that fuel cut was set at a certain psi although when trying to set my boost controller up somtimes it cuts at 1.1 then maybe 1.07 and so on, oh and that kpa!
thanks
any ideas?
Re: any ideas?
Hi,
Is the fcd soldered in to the loom?
Or have you used the crappy crimp blocks.?
I had this problem before i soldered into the loom
Zero.
Zero.
Re: any ideas?
Your fuel cut on a rev 2 should cut in around 83.362 kpa.
So i reckon you must have a badly fitted FCD (fitted previously)or a spilt in a hose to the actuator
Zero
Zero
