[Mk2] [Turbo] Better air intake temp sensor and positioning.Results page 6.
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
PostPosted: Thu Nov 19, 2015 9:39 pm    Post subject: Reply with quote Reply with quote including images
jimGTS wrote:
dyno? [Mr. Green]
Ambient 11.9 degrees, 23 degrees at 1.95 bar, no knock/det at all, so win, win, both for this mod and the chargecooler [Mr. Green] [Wink]
Back to top
User is offline
jimGTS
Premium Member
1997 Toyota MR2 Mk2 Turbo Rev4
PostPosted: Sun Jan 10, 2016 7:35 pm    Post subject: Reply with quote Reply with quote including images
Though I can't log what the oem sensor is telling the ecu.
I finally fitted the auber intake temp gauge.
RTD sensor I fit in the side 1/8 port on the inlet manifold by 4th runner.
Ambient temps today 7-9c (confirmed by gauge)
Cruise I was getting 16-18c
On boost max I saw was 25c which dropped to 18-20c after 10-20seconds.
Not tried any pull after pull after pull, as was wet outside.
Parking at the petrol station, only showed 35c when I returned (heatsoak).
Soon came back down fast.
I need to test in warmer weather and more pulls, but I like the setup!
Video showing it working.
Peak number recording, adjustable alarm/led warning.
Fast reacting 3 wire rtd sensor.
http://youtu.be/wFpC1sgBnjM
[thumleft]
Back to top
User is offline
Ryan S
PostPosted: Sun Jan 10, 2016 9:38 pm    Post subject: Reply with quote Reply with quote including images
Do either of you have fans on the pre-rad? If so how much of a difference do you see during a "heat soak" period?
_________________
Back to top
User is offline
PostPosted: Sun Jan 10, 2016 10:16 pm    Post subject: Reply with quote Reply with quote including images
I don't have fans, I don't get much in the way of heatsoak because the sensor is away from the hot engine however I still need to test it in real world conditions, ie. a hot day and sitting in heavy traffic or doing hard pulls in the same conditions etc.
I pretty much put the car off the road as soon as it was dynoed so only have the dyno session and a little bit of testing before and after as of yet...
Back to top
User is offline
Ryan S
PostPosted: Mon Jan 11, 2016 6:44 pm    Post subject: Reply with quote Reply with quote including images
Cool, I think i'll stick fans on anyway. Just have them on a switch to begin with.
Back to top
User is offline
jimGTS
Premium Member
PostPosted: Mon Jan 11, 2016 6:57 pm    Post subject: Reply with quote Reply with quote including images
im on a sidemount, so no pre-rad or fans for me [blackeye]
Back to top
User is offline
Ryan S
PostPosted: Mon Jan 11, 2016 7:31 pm    Post subject: Reply with quote Reply with quote including images
So you are Jim, apologies!!
Back to top
User is offline
kirk
PostPosted: Tue Aug 01, 2017 9:08 pm    Post subject: Reply with quote Reply with quote including images
To bump an old thread. Looking to change mine out. Can these still be had and are they worth the change?
Back to top
User is offline
blogsy
PostPosted: Wed Aug 02, 2017 5:53 am    Post subject: Reply with quote Reply with quote including images
Yes they are good http://www.auberins.com/index.php?main_page=product_info&cPath=5_21&products_id=139
Back to top
User is offline
jimGTS
Premium Member
PostPosted: Wed Aug 02, 2017 9:44 am    Post subject: Reply with quote Reply with quote including images
mines still going very well...
Back to top
User is offline
kirk
PostPosted: Wed Aug 02, 2017 9:21 pm    Post subject: Reply with quote Reply with quote including images
Link to the actual sensor? The one above is the to the gauge. Not really interested in that. Also I believe an adaptor is required?
I've heard it doesn't fit far enough into the intake to be as accurate. No idea how true that is.
Back to top
User is offline
jimGTS
Premium Member
PostPosted: Wed Aug 02, 2017 11:32 pm    Post subject: Reply with quote Reply with quote including images
Fit far enough compared to what?
Back to top
User is offline
blogsy
PostPosted: Thu Aug 03, 2017 6:21 am    Post subject: Reply with quote Reply with quote including images
Tick the box for the 4m one http://www.auberins.com/index.php?main_page=product_info&cPath=5_22&products_id=182
Back to top
User is offline
jimGTS
Premium Member
PostPosted: Thu Aug 03, 2017 9:49 am    Post subject: Reply with quote Reply with quote including images
http://www.auberins.com/index.php?main_page=product_info&cPath=5_24&products_id=167
Back to top
User is offline
blogsy
PostPosted: Thu Aug 03, 2017 10:59 am    Post subject: Reply with quote Reply with quote including images
Was that the one Jim, It was that long ago I can't remember. I would have to take mine out to look at it, but I'm sure you are right. I drilled a hole in my st205 charge cooler and had a threaded bung welded on. fitted it just before the rubber neck on the throttle body. Works really well.
Back to top
User is offline
jimGTS
Premium Member
PostPosted: Thu Aug 03, 2017 11:04 am    Post subject: Reply with quote Reply with quote including images
Well one you linked too says EGT sensor, I thought we was talking about air temp [Smile]
They look near enough identical just rated for different temps.
Back to top
User is offline
killerferret666
Premium Member
PostPosted: Thu Aug 03, 2017 11:11 am    Post subject: Reply with quote Reply with quote including images
Jim,
the linked one has 3 wires. I presume you just connect two of them? Considering switching to this sensor as I'm just about to install the Rev2 forged block with Rev 3 sensors / loom etc...
_________________
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
Back to top
User is offline
jimGTS
Premium Member
PostPosted: Thu Aug 03, 2017 11:19 am    Post subject: Reply with quote Reply with quote including images
think it has yes, but please bare in mind this sensor setup does and is designed to hook up to their gauge, so im sure i would have used all 3 wires when hooking up.
Back to top
User is offline
blogsy
PostPosted: Thu Aug 03, 2017 5:00 pm    Post subject: Reply with quote Reply with quote including images
All the instructions are at the bottom of each page on the site http://www.auberins.com/images/Manual/PT-AIR-NPT.pdf [thumleft]
Back to top
User is offline
kirk
PostPosted: Thu Aug 03, 2017 6:02 pm    Post subject: Reply with quote Reply with quote including images
The stock sensor.
I'm a bit confused. I thought you originally used a triumph sensor with a machined adaptor. All I'm seeing is EGT probe kits.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 7 of 8
Jump to:
