[Mk2] [Turbo] Looks To Nice I need some help
Goto page Previous  1, 2, 3, 4, 5
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
androo007
Premium Member
PostPosted: Wed Jun 28, 2017 4:37 pm    Post subject: Reply with quote Reply with quote including images
I'm always on the hunt, never seem to find them! [Twisted Evil]
Back to top
User is offline
rev2rich
Premium Member
1991 Toyota MR2 Mk2 Turbo Rev2
PostPosted: Sat Jul 01, 2017 3:56 pm    Post subject: Reply with quote Reply with quote including images
So the 5 block has been delivered and ever thing looks good... so should I go the 2.2 route and just get done or stay 2. [thumleft]
Are their any down side if going the 2.2 route? As in rev limated ect
Cheers Rich
Back to top
User is offline
C35Rob
Premium Member
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Sat Jul 01, 2017 5:19 pm    Post subject: Reply with quote Reply with quote including images
Cheers Rich
Generally speaking;
Longer stroke = worse rod/stroke ratio, higher piston speeds so increased wear, higher bearing loading, greater piston side loading and friction, less keen to rev as hard as a shorter stroke motor but better low down torque, and obviously the extra 200cc is a bonus.
Short stroke = the exact opposite of longer stroke.
I'm not aware of many (only one off the top of my head in the UK) who have built a 5s block up with a 3s crank, but if I were in the position you were in that's what I'd do - 86mm stroke 3s crank and 87.5mm pistons to give you a 2069cc motor, However other people's opinions may vary.
_________________
Back to top
User is offline
ashley
Premium Member
PostPosted: Sat Jul 01, 2017 8:30 pm    Post subject: Reply with quote Reply with quote including images
xx
Back to top
User is offline
rev2rich
Premium Member
PostPosted: Sun Jul 02, 2017 9:55 am    Post subject: Reply with quote Reply with quote including images
Thanks for the Imput lots to think about... I do like the high rev 3's crank I have at the minate and it is already knifed edge balanced so makes more sense to use and my set up currently is making 400whp and comes In nice and early
I will keep hold of the 5s crank as I probably want more power in the future so a 2.2 will make it a nicer build and would cut down on the lag of a bigger turbo
Suppose any one want to give me a parts list I would need as I currently have brand new every thing on the engine and would want to reuse as much as possible
[thumleft]
Cheers rich
Back to top
User is offline
rev2rich
Premium Member
PostPosted: Thu Jul 06, 2017 7:18 pm    Post subject: Reply with quote Reply with quote including images
So with further inspection the block is not repairable so time to crack on with the 5s block.. [thumleft]
Back to top
User is offline
androo007
Premium Member
PostPosted: Fri Jul 07, 2017 9:20 pm    Post subject: Reply with quote Reply with quote including images
Rich the only other option you have is to use a 98+ NA block. Keeps 3s with the strengthened waterpump area. Just needs oil feed for turbo tapping.
An option if you wanted to reuse all the 3s parts.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 5 of 5
Jump to:
