[Mk2] [Turbo] Looks To Nice I need some help
Goto page Previous  1, 2, 3, 4, 5  Next
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
rev2rich
Premium Member
1991 Toyota MR2 Mk2 Turbo Rev2
PostPosted: Fri Jun 23, 2017 2:35 pm    Post subject: Reply with quote Reply with quote including images
As far as I have read all the blocks Crack from rev1 to 5s
From what I have read a lot of people say it has something to do with cooling and it is a thermal shock when the thermostat opens it pushes cold water towards the water pump and this were the crack appear..
It is pot luck when they were casting.. A 5s block would be great but would make me change my hole build as I have a rev2 head ( no idea if it fits on a 5s )
I want to build a bullet proof block.. so thinking open deck sleeves as this will disperse the cool water quicker and completely removing the thermostat so the shock of the cold coolant would not affect the block...
I have a rev2 block that I know the history of and with it on a engine stand would allow more access to add more material to the weak area..
This is my thinking but would love to hear other peoples thoughts [thumleft]
Back to top
User is offline
androo007
Premium Member
PostPosted: Fri Jun 23, 2017 3:46 pm    Post subject: Reply with quote Reply with quote including images
If you want bulletproof afraid the only direction is late 5S.
The cheapest way I think is to get a block over from ATS. If you want i'll get one with you, and we can halves on shipping / come to an arrangement.
Your head will be fine
Back to top
User is offline
ashley
Premium Member
PostPosted: Fri Jun 23, 2017 3:52 pm    Post subject: Reply with quote Reply with quote including images
xx
Back to top
User is offline
rev2rich
Premium Member
PostPosted: Fri Jun 23, 2017 4:01 pm    Post subject: Reply with quote Reply with quote including images
It happens .... I will look into a 5S now and see what is about.. any thing else would have to be changes or do all the parts marry up as in water pump ect
cheers [thumleft]
Back to top
User is offline
androo007
Premium Member
PostPosted: Fri Jun 23, 2017 4:12 pm    Post subject: Reply with quote Reply with quote including images
Pete told me that ATS sell bare blocks for $400 plus shipping. Lots of changes I think.... Ashley can advise having been there done that
Back to top
User is offline
ashley
Premium Member
PostPosted: Fri Jun 23, 2017 7:08 pm    Post subject: Reply with quote Reply with quote including images
xx
Back to top
User is offline
androo007
Premium Member
PostPosted: Mon Jun 26, 2017 4:33 pm    Post subject: Reply with quote Reply with quote including images
rev2rich wrote:
It is currently running 400whp
Meant to ask Rich - is that 400whp = ~500 crank hp? or 400hp?
Back to top
User is offline
rev2rich
Premium Member
PostPosted: Mon Jun 26, 2017 5:42 pm    Post subject: Reply with quote Reply with quote including images
400 at the wheels @1.6bar [thumleft]
Back to top
User is offline
androo007
Premium Member
PostPosted: Mon Jun 26, 2017 7:00 pm    Post subject: Reply with quote Reply with quote including images
Oh wow nice! Do you have a dyno? What turbo are you running ?
Seems that 500 crank really is the limit of the 3s block. I assume through no welding you can't repair that area to make it stronger than stock even for another 10k use?
I know what I'm typing sounds dumb but once it's cracked the stress is relieved. Could you weld up the leak and keep going? Is there anything else to crack further? It seems the crack is always on the edge...so like if you did seal it up and strengthen somehow, could that actually hold for a reasonable time? It's not like an internal cylinder wall crack.
Back to top
User is offline
rev2rich
Premium Member
PostPosted: Tue Jun 27, 2017 2:13 pm    Post subject: Reply with quote Reply with quote including images
I don't have the 1.6 bar Graph but I have the 1.4 and the data sheet this is were we found that the waste gate and b.o.v were restricting the turbo
I have spoken to industrial metal epoxy company Belzona and waiting on their technical team to get back to me! But I will be doing a 5s build straight away as this is only a temp solution
http://www.belzona.com/en/products/1000/1511.aspx
Cheers Rich
Back to top
User is offline
ashley
Premium Member
PostPosted: Tue Jun 27, 2017 3:29 pm    Post subject: Reply with quote Reply with quote including images
xx
Back to top
User is offline
rev2rich
Premium Member
PostPosted: Tue Jun 27, 2017 3:46 pm    Post subject: Reply with quote Reply with quote including images
I am using a EFR turbo so the B.O.V is apart of the turbo and the part that feeds turbo is small and restricts the air and sends some pressure back thou the system... The actuator/ Watergate / boost controller (same unit ) would not allow the boost to get over 1.4bar New one allows 2bar.. [thumleft] [thumleft]
Back to top
User is offline
C35Rob
Premium Member
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Tue Jun 27, 2017 3:47 pm    Post subject: Reply with quote Reply with quote including images
maybe the WG spring was too weak and the boost controller is struggling to control, and/or the BOV is leaking.
anyway..
we use the exact same belzona stuff at work (harsh marine engineering environment) and it is very good.. but not the right stuff for this situation imho.. the block is cracked, to repair it properly the crack would need to be ground out, welded, pre and post heated and then you'd need to at the very least check the deck for warpage. at that point you may as well re-block your engine.
preparing the block in situ and applying the epoxy over the crack will more than likely stop the leak and get you though this year, if you the wanted to attack it over winter, but its definitely not a permanent solution.
if you do go 5s and cost is offputting it may be worth keeping the 3s crank, that way you could sell the 2.2 crank, and don't need to go to the expense of new rods or getting the 5s crank ground..
_________________
Back to top
User is offline
rev2rich
Premium Member
PostPosted: Tue Jun 27, 2017 4:03 pm    Post subject: Reply with quote Reply with quote including images
That run the waste gate / actuator was wide open just very restrictive so turbo smart do a direct replacement to solve this [thumleft]
I am only using it for a while as it is a 15mm crack I moving the car to body shop and getting it ready for the 5s block and My brake set up and rebuilt ABS hubs to allow me to use traction control / anti lag /launch control.. still so much left to do
I think I will go down the 2.2 road so my turbo can come in sooner but the will see what I do [thumleft] [thumleft] [Brick wall]
Back to top
User is offline
Gee Man
Premium Member
1998 Toyota MR2 Mk2 Turbo Rev5
PostPosted: Tue Jun 27, 2017 6:26 pm    Post subject: Reply with quote Reply with quote including images
Gutted for you mate, I've been there and it's rough! What pistons were you running ?
Back to top
User is offline
Danbob
PostPosted: Wed Jun 28, 2017 6:11 am    Post subject: Reply with quote Reply with quote including images
Back on the block topic, late 3SGTE and 3SGE blocks are totally different around the water pump area, significantly thickened, same as the later 5s's are.
I have an NA block in the garage with photos to demonstrate this. I think it was a rev4 block but honestly can't remember now, certainly was post rev3.
They are easy to spot though just look at the deck and you can see a big squared off area around the water pump rather than following the contour of the cylinder.
Real shame that it's gone so early after all that work. I'm in the same boat as you with a rev2 block, hoping not to have the same misfortune!
Back to top
User is offline
Gee Man
Premium Member
PostPosted: Wed Jun 28, 2017 7:10 am    Post subject: Reply with quote Reply with quote including images
I'm currently running a 3SGE NA block and you're right they do have distinct differences. [thumleft]
Back to top
User is offline
rev2rich
Premium Member
PostPosted: Wed Jun 28, 2017 10:27 am    Post subject: Reply with quote Reply with quote including images
Managed to get a late 5s block 1998 should be delivered next week [thumleft]
Back to top
User is offline
androo007
Premium Member
PostPosted: Wed Jun 28, 2017 12:49 pm    Post subject: Reply with quote Reply with quote including images
WHO WHAT WHERE? Jammy sod
Back to top
User is offline
ashley
Premium Member
PostPosted: Wed Jun 28, 2017 2:44 pm    Post subject: Reply with quote Reply with quote including images
xx
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 4 of 5
Jump to:
