whats this?
boondougal
whats this?
Post by boondougal »
Just wondered if someone could tell me what this connector is that i have found on my 1989 n/a.
I'm stripping it out as its gong for a load of body work and a re-spray and under the carpet under the drivers seat i found this connector :-k
Any ideas? \:D/
Image[/URL][/img]
Image[/URL][/img]
tunna_uk
Re: whats this?
Post by tunna_uk »
I think that was for the Toyota Stereo amplifier fitted to some cars.
System-G
Re: whats this?
Post by System-G »
On early cars (Pre 87) there was a "sub" fitted under the driver's seat. The later version got rear speakers (which the earlier cars didn't get) and no "sub". It's not real sub - more like low-mids.
kevin..in
Re: whats this?
Post by kevin..in »
If you look around the car you will find lots of unused harness plugs as toyota used common harnesses for all cars but there are different specs for different markets so some plugs remain unused. could well be the plug for the undersaet speaker used on the MK1a but dropped in the UK on the MK1b the colours seem to be right for speakers :wink:
boondougal
Re: whats this?
=D> cheers guys, kind of thought that would be the case but i guess you don't know untill you ask!!
thanks for the info,,might be asking lots of questions when it comes to putting my baby back together again!!!
Tony jinxy froude
Re: whats this?
Post by Tony jinxy froude »
Theres quite a few of those in the car especially in the engine bay & under the dash.
Garrick i see the cog arrived safely then, hope its what you need, cheers, Jinxy :thumleft:
