[Mk2] [NA] Stereo not receiving power
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical
Author Message
rob6539
Premium Member
PostPosted: Sun Feb 16, 2014 8:18 pm    Post subject: [Mk2] [NA] Stereo not receiving power Reply with quote Reply with quote including images
Hi
I've bought a 3sge and the stereo doesn't work. The old owner has obviously had an aftermarket stereo fitted, so I've been left with the dodgy wiring.
I've connected the wiring up, as of a stereo wiring diagram, but it is not receiving any power (constant or ignition). The car has sub's behind the seats, so I'm assuming it also has an amp and that this amp will feed power to the stereo.
My problem is, I can't find where the amp is hiding!
Please help!
Back to top
User is offline
gerbil1028
Premium Member
PostPosted: Sat Mar 01, 2014 12:18 am    Post subject: Reply with quote Reply with quote including images
Did u have stereo bolted in as earths it. Or plug Ariel in as that also earths it then check for power
Back to top
User is offline
Peter Gidden - SBITS
IMOC Affiliated Company
2002 Noble M500
PostPosted: Sat Mar 01, 2014 2:45 am    Post subject: Re: [Mk2] [NA] Stereo not receiving power Reply with quote Reply with quote including images
OEM amps are behind the trim panel below the N/S 1/4 light.
_________________
Engine Builder to Simon Hicks - 555bhp 532ftlbs
Brighton National Speed Trials Class Winner 2011
Brighton National Speed Trials Class Winner 2010
Brighton National Speed Trials Class Record Holder 2010 on
Back to top
User is offline
keiith9849
PostPosted: Fri Jun 23, 2017 8:22 pm    Post subject: Reply with quote Reply with quote including images
I had a problem f the installer having used the bolt-in cage as the earth. Maybe run a new secure earth wire and work from there. Eating t the amp or the aerial is not the way to go.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical All times are GMT
Page 1 of 1
Jump to:
