[Mk2] [Turbo] aftermarket JVC 400 double din into active system issue.
gerbil1028
Post by gerbil1028 »
Bloody wiring.
Have the rca connector that plugs into car. Have rca splitter to condense down as stereo only has 2 outputs.
Have power but no speakers.
Where am I going wrong and getting ready to throw in bin.
gerbil1028
Re: [Mk2] [Turbo] aftermarket JVC 400 double din into active system issue.
madbasshunter
Post by madbasshunter »
Have you connected the remote lead (generally blue or blue and white) which switches the amps and aerial on.
RyanRs wrote:
Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously , you don't know the answer to this? and you call yourself a car mechanic :shock:
gerbil1028
Lead at top of pic is remote from car loom and not connected to stereo as couldn't find the blue and white lead on hu.
I have now connected car loom remote to Ariel lead that had Ariel/remote on it.
I then connected this to the hu lead I found which was blue/white with grey dashes.
Hopefully this works.
Does amp/remote need to be connected to kick Ariel in as in make it go up.
gerbil1028
Ariel works now still no sound.
Have no battery using a jump pack that's a tad flat would this cause issues.
gerbil1028
Found problem. Last owners cut out all the speakers.
Return to “ICE and Security”
