Is there anything I should check before I change to uprated cams? How do I go about timing them?
Ian
Fitting new cams to '89 mk1
- Lauren
- Premium Member
Re: Fitting new cams to '89 mk1
Just time them up using the stock timing marks on the cam wheels and the head/timing belt back cover.
You need to check the clearances as this will no doubt change and you'll need a collection of shims if you have them of varying sizes. If you are lucky you will be able to swop your shims around to make up the correct clearance for all...
Snap on dot co dot uk do a tool that allows you remove the shims with the cams in place for around £20.
2020 GR Yaris - Circuit Pack
- Lauren
- Premium Member
Yep thats it. Mark bought one last year for his rebuild.
Snap-on with a reasonably priced tool the world has gone mad
Thanks, I'll give it a go
