limp mode, and dodgy idle
TUBBY-DEUCE
Post by TUBBY-DEUCE »
hi, it seems the car has decided to go into limp mode, i cant rev past 3k, and when at operating temp the idle is rough, any ideas please :?
TUBBY-DEUCE
Re: limp mode, and dodgy idle
i have no engine light coming on neither, the bulb works, goes out as it should
mrspete
Post by mrspete »
Strange the light goes out in limp mode
I have a reader for JDM if you want to try it
Pete
TUBBY-DEUCE
that would be great mate, i got a bluetooth jobby of ebay, and apps on my phone , im hoping that will work. can i get back to you on that offer :thumleft:
TUBBY-DEUCE
anyone with any suggestions, im baffled, it wont rev past 3k, i can find no info online other than cats may be blocked? or chain tensioner is slack?
any help or suggestions please
synXero
Post by synXero »
Let me say first off I have no experience in turbos but sometimes a layman suggestion is better than nothing.
Quite often it seems that little errors that cause no CEL are ignition related, or dirty sensors/groundings. In this case, I reckon it might be worth checking over your ignition components.
mrspete
Post by mrspete »
Give the MAF a clean and reset the ECU which you might have done already
TUBBY-DEUCE
under the hood it has extra earth cables, ive done the maf, no luck. i will check coils tonight etc, then im going to to compression weekend and gut cats, if theyre not gutted already.
it seems weird to me as limp mode is 4.5k rpm im told? no cel warning neither which is weird, can you do a paperclip trick on diagnosis port on jap imports?
cheers for the help
synXero
Post by synXero »
TUBBY-DEUCE wrote:under the hood it has extra earth cables, ive done the maf, no luck. i will check coils tonight etc, then im going to to compression weekend and gut cats, if theyre not gutted already.
cheers for the help
You can check for error codes using a paperclip yeah. It will give you flashes on the dash indicating an error code, if you have one.
Jam a clip into TE1 and E1. It may or may not give you something.
TUBBY-DEUCE
i have a mk3, i thought that was mk2
synXero
Post by synXero »
...Sorry mate, I assumed by looking at your username, my mistake.
mrspete
Post by mrspete »
Paper clip method will work, bridge terminals 4 & 13
TUBBY-DEUCE
thats ok buddy, apeciate the time and help, i will try the pins 4 and 13, many thanks
TUBBY-DEUCE
ok, bridged 4 and 13, and got steady flashes of abs light, im assuming thats all clear, surely if it was something electrical like a sensor it would throw a fault up?
mrspete
Post by mrspete »
Check the condition of the precats by taking out one or both o2 sensors shine a torch in and inspect, if they are not there it has either been decatted or the remnants are in the main cat causing loss of power and maybe engine destruction, if the main cat is blocked im sure I have a decat pipe somewhere for you to try
Pete
TUBBY-DEUCE
thanks very much pete, il look over the weekend hopefully, fingers crossed......i said id never buy a mk3 but it certainly puts a smile on my face around the bends even limited to 3k rpm.....hopefully i can sort this out and drive it properly
Return to “MR2 MK3 2000-2007”
