mk3??
jonnie m
mk3??
Post by jonnie m »
Hi. I have a mk1 but thinking of getting a roadster but there seems to be talk of the usually bullet proof Toyota unit going pop on a regular basis,so im looking to find out the script on this before buying. thanks!
sam1176uk
Re: mk3??
Post by sam1176uk »
Do a search for pre-cat failure and all will be revealed, the consensus appears to be to go for a post 2003 model and you will be fine.
mrspete
Re: mk3??
Post by mrspete »
As said, if you can afford buy a facelift model if not you will have to do all the checks etc
If your near Norwich you can have a look at mine and go for a spin and we will go through what to look at, Ive had mine for 13 years now with no problems
Pete
Return to “MR2 MK3 2000-2007”
