I have an GEMS ecu but don't know if it's for a mk1a or b. What difference, if any, will this make? I tried an early ecu in my '89 car and it started and idled so the idea that one would work and not the other went out the window.
Has anyone else got/used a GEMS unit? Is it easy to update?
Cheers,
Ian
MAP and AFM ECU
MAP and AFM ECU
Is the GEMS a modified Toyota ECU? If it is and still has the Toyota part number on it let me know and I will ask Jeremy Ross for info. Richard Morgan
Re: MAP and AFM ECU
I've just found DTW Engines phone no if you want, it was in my MR2DC members handbook: 01273 422128
Address:
Stort Mill Industrial Estate
Riverway
Harlow
Essex
HTH
Address:
Riverway
Harlow
Essex
HTH
Re: MAP and AFM ECU
Thanks, I'll give them a call.
Does anybody have any software that can be used to connect an ECU to PC?
Ian
Ian
