hi guys.
the horn has died on my car . therefore ive got some more sporty twin tone horns. nothing over the top just sound nice.
( small mod i know lol )
but to make the job more easy is it a good idea to remove the front bumper? how easy is it to remove?
many thanks.
james
removing the front bumper... horn replacement
- Lauren
- Premium Member
Re: removing the front bumper... horn replacement
I would consider you stark raving barking mad, if you removed the front bumper just to replace the horn!
2020 GR Yaris - Circuit Pack
yes... yes i am .
by that it dosnt sound too much of a walk in the park
I think what Lauren is getting at is that there is absolutely no need to remove the front bumper to remove the horn?
IIRC - can you not just remove the cover over the radiator, and it is right there in front of you? (when looking down of course)
"If in doubt - just make the numbers up!"
yes thats where the horns arecan you not just remove the cover over the radiator
kevin..in wrote:yes thats where the horns arecan you not just remove the cover over the radiator
My point exactly Kevin ????
i was thinking more on the placement of the new ones.
anyways. fitted and working fine
(didnt remove the front bumper)
Not playing the Dukes of Hazard tune are you....
Wayne as your post began with "can you not" I assumed there was uncertainty so my post was to clarify the situation. sorry If I caused any offence I just like to be clear if I know something for certain I will say sokevin..in wrote:
Which horns have you fitted? My horn is dead and sounds poor, need sumthing with abit more street cred.
kevin..in wrote:Wayne as your post began with "can you not" I assumed there was uncertainty so my post was to clarify the situation. sorry If I caused any offence I just like to be clear if I know something for certain I will say sokevin..in wrote:
No worries Kev - no offence taken, takes quite alot to offend me anyhow!
AAAAAHHHHH Kevin with an in as in kevin..in does'nt realy bother me but thought I would point out the reason for my log on nameNo worries Kev - no offence taken, takes quite alot to offend me anyhow!
un1eash wrote:Which horns have you fitted? My horn is dead and sounds poor, need sumthing with abit more street cred.
Try the Stobel Nautilus twin tone. Needs to be fitted using a relay but sounds great! I have one fitted to my IS300.
