Please could you tell me where the petrol relay is located on a 1988 MR2 MK1?
Thanks. PhilipWardle [email protected]
Posted by Richard Morgan
HELP - WHERE IS THE PETROL RELAY?
Re: HELP - WHERE IS THE PETROL RELAY?
The COR or Circuit Opening Relay controls the feed to the fuel pump on a mk1,this can be found attached to the ecu in the boot.There will be a blue wire coming from the COR,this is the feed from relay to pump,the starter motor cranking and ecu switch the COR open,hope that helps.
