[FINALIZED] Rev3 turbo Black
Gullzter
Rev3 turbo Black
Post by Gullzter »
For sale is my black standard rev3 turbo gts T-bar
Good points:
Starts up perfect
Idles great
Engine pulls strong in all gears
Turbo boosts full with no smoke whatsoever
Gear change is nice
Clutch strong
Cloth interior in good condition
Jvc cd head unit
Fairly new central locking toad alarm
Suspesion and steering strong
Apexi induction put on 500miles ago with heat sheild
Short shift kit
Genuine hks Ssqv bov
Smoked front sidelights/reflectors
Bad points:
Oil leak possibly from turbo
Noise coming from engine bay when changing gear at lower speeds (possibly coming from gearbox, however gearbox is strong and changes through all gears fine)
Gear lever needs adjusted as sits slightly to right
Driver wheel buckled and all wheels need refurb
Tyers all wearing on inside however are only about 2000miles..
Alignment/tracking/geomatry needing done
Clocks stopped reading properly, reads about 5mph under actual mph
Only have 1 key, a little worn so will get new one cut
Slightly bubbling at top driver side windscreen
Bottom of drivers door has a patch missing through rust
Passenger side door has been keyed very lightly
(May be able to replace both doors for new owner)
Work carried out recently:
Apexi induction (powder coated a dark grey/black by previous owner)
New iridium grade 7 plugs
Rotor arm
Dizzy cap
Front springs replaced, front uprated gtschris top mounts, front drop links (all about 1000miles ago)
Tbar silicone trick done
Still have rear drop links to fit but doesnt need replacing however if i get time ill do this
Car has 126,000kms on clock
Mot til May 2014
Tax til Nov 2013
Imported in 2005
Reason for sale because i work 6-7days a week and just dont have the time to give her the love and attention she needs with the issues. Will make a stunning car with a bit of time
Some pics:
http://m1240.photobucket.com/albumview/ ... 2&newest=1
More pics can be sent on request by email
The car owes me in excess of £3000
Looking for around £2000
Any more info shoot me a pm
Regards
Munir
:cry:
Gullzter
Re: [FINALIZED] Rev3 turbo Black
Post by Gullzter »
This is on hold for the time being while i get the turbo fully rebuilt, new IC, DP and SS exhaust system put on
Feedback Bot
Post by Feedback Bot »
