I recently posted for some advice on replacing the suspension on a Mk1b and it was really helpful. I am now trying to narrow down which suspension bushes to use. This will be influenced by price but i also want to use bushes that are not too firm and jarring.
I am v.tempted to use high and tight prothane bushes as they are cheaper but i assume that there could be differences in the way the bushes feel due to the materials used to give a more sporty or more relaxed ride? There do seem to be quite a few makes out there, e.g. superflex, powerflex, High & Tight prothane bushes and probably more that i haven't heard of?
Does anyone have more experience of whether the type of bushes used makes much difference to the feel of the car?
Suspension bushes
Re: Suspension bushes
I imagine the three polyurethane bush types are pretty much the same, with just the cost being different. They will firm up the ride and lead (IMO) to a lot more feedback through the steering wheel (but I did change my ball joints and trck rod ends at the same time). The ride will be a bit harsher but it is worth it as the driving experience is a lot more rewarding.
I have the H&T bushes on my Mk1 and they made a imense difference, for the better.
The rubber Toyota and TRD bushes aren't too expensive, however there are a couple that you can't buy without buying the whole suspention component (lower control arms IIRC) which is pricey.
HTH
Chris
HTH
Chris
To be honest widster, comparing poly bushes is going to be a tough job. I would imagine no two cars are the same now what with different shocks, springs, wheels and tyres and so on. I would go with the H&T option if I were you, as like you have mentioned, there a bit on the cheaper side.
Poly bushes are well worth the money and effort in my opinion.
Thanks for the replies. I am going to take your advice and try the poly bushes from High & Tight. Will let you know how i get on.
Widster
Widster
You know it makes sense.
