Which oil is best for these ol' engines?
Goto10
Post by Goto10 »
As the subject reads, best oil for a mk1 with high mileage?
Fully synth? Mobil1 15/50 maybe?
kevin..in
Re: Which oil is best for these ol' engines?
Post by kevin..in »
not mobil 1 way too thin on a high mileage engie you will end up with oil leaking from every joint
User avatar
Lauren
Post by Lauren »
Steve would just use a 10/40 Magnatec. Its absolutely fine with an engine like the 4AGE
RichardMorgan
Post by RichardMorgan »
The September issue of the MR2 MK1 Club magazine will carry an article by Club Technical Advisor Alan Jones called
“OILS, FILTERS, CHANGES, LIFE’S RICH PATTERN” This contains some very useful info both on oils and filters. Richard Morgan
stevenb
Post by stevenb »
I would use nowt else except Castrol GTX magnatec 10w40.
Use a genuine toyota oil filter and your sorted.
Ive tried various oils in the past including mobile 1 and none were as good as the magnatec. :D
spudgun
Post by spudgun »
I'm in the middle of a 2 year service on mine. Using valvoline this time as the autofactors were doing a bit of a deal on it. Will let you know how I get on.
User avatar
BenF
Premium Member
Post by BenF »
Goto10 wrote:As the subject reads, best oil for a mk1 with high mileage?
Oilman has been posting up some articles on stuff like this - do a quick search and have a look in the knowledgebase too.
The principle is to keep to the original grade of oil, but increase the quality of the oil used...
I'd use at least a Semi-synth given you're going to be tracking the car (?) and oil temps will be higher. The semi and fully synths are more temperature stable and less likely to break down
Mk1 Turbo Powered Steve
Post by Mk1 Turbo Powered Steve »
I have always used Magnatec on mine ,seems about the best for our cars,as far as i know.
Goto10
Post by Goto10 »
Lauren wrote:Steve would just use a 10/40 Magnatec. Its absolutely fine with an engine like the 4AGE
Cheers all, bought some Magnatec in the end as suggested.
*DeathStar*
Post by *DeathStar* »
did mine today.
nice toyota filter and some 10/40 magnatec and shes a happy lady.
