[Mk2] [Turbo] S2000 Aerial Fitted
Nic
Post by Nic »
Sourced an S2000 aerial assembly from a breakers, here are a few pics. It was a straight swap for the stock retractable aerial, just need to buy an aerial lead extension and wire in the power for the built in signal amplifier.
JayUK91
Re: [Mk2] [Turbo] S2000 Aerial Fitted
Post by JayUK91 »
Nice mod, good thinking!
dawesy
Post by dawesy »
looks good :thumleft:
im sure i have a stock Ariel lead you can have some where, is yours missing or is it just that it doesn't reach?
matt-mr2
Post by matt-mr2 »
cool mod :clap:
Nic
Post by Nic »
dawesy wrote:looks good :thumleft:
The lead is about 10-15cm too short because the plug on the new aerial points inwards towards the boot whereas the plug on the stock aerial points forwards.
Thanks for the offer, I'll see if I can pick up a short extension lead at Halfords tomorrow.
Looks good mate, where's your spoiler gone? :-k
Nic
Post by Nic »
RedMR² wrote:Looks good mate, where's your spoiler gone? :-k
The wing had water trapped inside so removed it to dry it out, need to sort out some gaskets/seals so I can refit, it's on the list of jobs to do :D
User avatar
loudandproud205
IMOC Organiser
Post by loudandproud205 »
What is is like with the spoiler in place?
Got boost?
Kinda!!!
0.3 bar FTL
Nic
Post by Nic »
loudandproud205 wrote:What is is like with the spoiler in place?
I've not put the Rev 5 wing back on yet but should be fine as it sits in the same location as the stock aerial. Not sure about the early model wings, the aerial is a little thicker - 22mm diameter at the base of the flexible aerial mast narrowing to 10mm further up - so may not be compatible.
malwhiterev3
Cheers, mine has snapped off so just after a universal replacement,
Post by malwhiterev3 »
I only need the mast
Nic
Re: Cheers, mine has snapped off so just after a universal replacement,
Post by Nic »
malwhiterev3 wrote:Cheers, mine has snapped off so just after a universal replacement,
Do a search on Ebay, new masts are quite cheap on there.
armstrong
Post by armstrong »
looks better than the ridiculous standard "RC car" style aerial!!
