Superedition project part 1 of 3 completed ~ Pic Heavy ~
autobody
Premium Member
Post by autobody »
Hi everyone,
My name is Imran and based in Manchester. in 2010 I sold my supercharger but soon got itchy feet and wanted another SC as a project. So I got myself a superedition which needed quite a bit of work.
Three issues with the car:
1) RUST
2) engine overheats on longish runs
3) full respray
In the last few months I took the car to Gary to sort the rust on the car. And am pleased to say stage one is now complete.
I have copied the images and text from another forum so it may not flow right:
Car when I got it:
The rust:
Look what I found hidden behind the front driver side wing, all this damp stuff has caused lots of damage to the door post, see images below:
Door post - very close to where the door bolts on, cant been a good place to rust.
Found a small hole, did have a poke around and does looks quite solid:
More rust on the floor, this is that the front driver side floor:
Driver side sill, looks good apart from one hole in the middle:
Rear driver side floor:
Some new parts for the car: front bumper bar for 134 pounds from Toyota, they originally wanted 150+ but asked for a discount and got it 8) ... Going to make sure the bar get protected well to stop it from rusting.
Also I found a newish number plate bar in my store room (forgot I had it :oops: ). So after the welding the front end should be like new...
Need a better bumper skin though as the current one is wavy at the top ( maybe its on to tight :think: )
Also got a set of new APEX springs for 70 pounds (they were not my 1st choice as I wanted to buy the Fensport springs but cant afford them and need the springs to pass the MOT.
Okay the most important parts I have are the replacement panels, I've managed to get two sills (not sure if I need them to be honest) and both rear arch kit sets...
autobody
Premium Member
Re: Superedition project part 1 of 3 completed ~ Pic Heavy ~
Post by autobody »
I have copied the text and image from the mk1 forum:-
Hi all . i have now started to restore the se ,she's a bit of a rusty shed at the moment:lol: but that is about to change , its to me the mk1 to have, very rare and this car is mental fast with the engine mods . She need a lot of work to put her back on the road , its a good job imran brought her and he is a mk1 enthusiast otherwise we would have lost another se .
pics of work done .
striping car down
the bumper bar is fubard so its going
the passenger A post is rusted so i started here first
this area is a pain to get the shape right but it can be done .
autobody
Premium Member
Post by autobody »
More updates, again copied from the mk1 site:-
the next area is passenger side B post
this was cut out
a little bit more filling and it will be spot on
A post drivers side
new metal welded in
new arches welded in
loads more work to do including floor pan .
autobody
Premium Member
Post by autobody »
The floor (passenger side) :angry:
leaking t bars have caused this damage .
remove the sound proofing to access the damage and it looks worse than it is , the rest is solid and the inner sills a rust free .
the only way to stop corrosion spreading is to cut it out , this is a rough cut to remove the damage first .
The replacement floor pan I got a while ago:
i have a floor pan to graft in , this will be fun and a bit off a pig but its straight forward if you take time .
autobody
Premium Member
Post by autobody »
Gary made good progress on the floor to day and the passenger side is now sorted . :+:
new piece cut to size
final marking out before cutting
trail fit
welded in place
other bits welded in
autobody
Premium Member
Post by autobody »
now painted with zinc enriched primer .
autobody
Premium Member
Post by autobody »
Copied from MK1 site:
hi, i have now done the drivers floor pan , this wasn't as bad as the passengers . all the sound proofing was removed to check the pan and i found water underneath the sound proofing so its a good job i checked .
damage to floor pan .
welded up
painted floor
a post plated
A and B posts painted with zinc primer .
corner welded in
autobody
Premium Member
Post by autobody »
a bit more done this weekend and its now coming together .
flat the primer when its gone off and sort out any imperfections then the top coat , happy days .
autobody
Premium Member
Post by autobody »
sorted the front chassis and lower cross member with new metal and is now soild .
and she now has some paint .
New Apex springs fitted:
autobody
Premium Member
Post by autobody »
Can now at home:
Me getting the car collected:
On the way home
New rear arches:
Finally home:
autobody
Premium Member
Post by autobody »
Some goodies for my car:
Super edition replacement stickers (not original unfortunately)
Original Toyota t-bar seals
3 piece split rims, (PIAA nakajima racing) the rims needs a polishing also the caps was missing, it took me a year to find them. I will post images of them in the next post as can't add to many images in a single post.
mirror t-bar:
Super edition floor mats:
autobody
Premium Member
Post by autobody »
Pic of the Momo gear knob
the momo steering wheel without the original cover:
I did manage to find a cover which fits the wheel, as I don't think I will be able to find a original steering cover.
Also I have 4 of these seats, two was from my 1st sc and the other two came with the car. So with the 4 seats, I will be able to have two mint seats for this car.
Am not sure if these are for the SE or just all aw11 but here is a pic for you guys, they sit behind the seat.
Toyota Tape player:
User avatar
LimeyMk1
Post by LimeyMk1 »
Brilliant. :clap:
Fancy doing my mk1? :lol:
autobody
Premium Member
Post by autobody »
Guess what's in the box, its 20+ years old...
Its original Toyota fog lights, they are brand new and never been on a car. I believe they came in the early aw11 and ae86. these are the 1st model that were out, then a few years later there was another set available which had different covers (black and silver) these are black and gold. The black and gold will suit the SE colour scheme I think...
all orange indicator lens
autobody
Premium Member
Post by autobody »
:lol: I took its to Gary (mk1dal) I did start it by cutting some of the rear arch and then I bottled it :D
MR2MK1MAD
Post by MR2MK1MAD »
Looks really good
Where did you get your replacement stickers
autobody
Premium Member
Post by autobody »
MR2MK1MAD wrote:Looks really good
from ebay, see link below:
http://www.ebay.co.uk/itm/1ST-GEN-MKI-J ... 242wt_1185
User avatar
Lauren
Post by Lauren »
Imran, did you not get the Super Edition visor decal from Chris?
It's just Mark sold him one of his super duper screen printed decals which is much better than vinyl.
autobody
Premium Member
Post by autobody »
Lauren wrote:Imran, did you not get the Super Edition visor decal from Chris?
O yeah I still got that, I just need a mint visor to put it on. I've already paid for two from ebay which were advertised as mint and they come all scratched :shock: :evil:
Steve Horrocks
Post by Steve Horrocks »
You don't live by the Snipe in Ashton do you buddy?
Sure I recognise it in the pics?
Gone, but never forgotten
Now with a mk1.5 & a NHB EP3
