Changing the Heater Matrix - the easy way!
Icsunonove
Post by Icsunonove »
Thanks to some pioneering work by Lauren, there is now an easy way to change a heater matrix.
The traditional way is to remove the whole dashboard which I believe takes about three or four hours (is that right Lauren?).
Lauren had problems with hers at the same time as me and she came up with a cunning plan:
Why not make a neat cut-out in the front boot and take the heater matrix out that way?
Well it works brilliantly and doesn't take long at all.
I've done a drawing of the cutout and I can email it as a pdf.
Hope this helps someone else
Best regards, Tom
(P.S Double click on the image to get a better view)
User avatar
Lauren
Re: Changing the Heater Matrix - the easy way!
Post by Lauren »
I should remind/tell people about the knowledge base:
http://www.imoc.co.uk/forums/kb.php?mode=article&k=5
Annoyingly the pics seemed to have dissapeared, but hopefully you get the idea.
