Advice please - rear wheel hub
paulcas
Post by paulcas »
Hi,
1 of my 4 rear hub bolts that hold the wheel one has sheered off !!
Can anyone tell me if I need to change the whole hub or just the bit that has the bolts going through it. And if so, how do I replace it. Step by step guide would be good, with photos would be even better - thanks.
Paul
paulcas
Re: Advice please - rear wheel hub
Post by paulcas »
paulcas wrote:Hi,
Paul
I now know what to do :)
Has anyone got a spare wheel stud bolt or suggest the best place to get one from - thanks.
frogger
Post by frogger »
CTP (Cheap Toyota Parts) or a Toyota Dealership.
And consider replacing all 4, unless that one only sheared because of a force put upon it which you are certain has only ever been put on that stud.
Wheels have been known to come off at speed due to sheared studs, so better safe than sorry
paulcas
Post by paulcas »
frogger wrote:CTP (Cheap Toyota Parts) or a Toyota Dealership.
frogger, good point, thanks.
Return to “MR2 MK3 2000-2007”
