Big flatspot on Bluetop 4AGE- but I think I might have an idea
Goto page Previous  1, 2, 3, 4, 5  Next
Author Message
toxo
PostPosted: Mon Mar 28, 2011 8:17 pm    Post subject: Re: ECU Reply with quote Reply with quote including images
aw11rally wrote:
Did blitz do an Access ECU for the AE86. The Blitz ECU I've just fitted to my Mk1.5's 3S-GTE looks identical to the original ECU, including code numbers Etc etc etc. The only differences being internal circuitry and some security style blitz stickers over the joints in the cover.
That's because the blitz access ECU *is* the stock part, with a techtom board soldered into it. They're not that much different from the stock ECU, generally just have raised fuel cut / boost limit / rev limit.
_________________
Back to top
User is offline
Lauren
PostPosted: Mon Mar 28, 2011 8:19 pm    Post subject: Reply with quote Reply with quote including images
Mark's text crossposted from AE86 forum:
ok, took a look at the ecu today, tbh i was just resetting the fault codes but noticed it had spacers on the front cover and holes cut to allow access to dip switches and a small adjustment pot.
So had it out and found a daughter-board installed, the origina ND cpu has been desoldered and the board soldered in place using wires, i'd say quite well done.
The daughter board contains a bunch of 74 series logic, the original CPU and a 256kbit EPROM amongst a few support components.
At a guess i would say they are tweaking the ecu into pulling the maps from the external EPROM rarther than the internal ROM thats built into the main ND CPU... i do know a little of the CPU inner workings thankfully.
There are no manufacturer marks on it at all, if anyone can tell us what it is and what the dip switches and adjustment pot do it would be most helpful.
In related news, between taking it out and putting it back it seems to have cured the flat-spot. Maybe unplugging and resetting it has cleared a fault code...
_________________
2013 GT86 Injen Induction. Volks Racing TE37s & TRD Aero Fins, Mega sounds. TEIN Street Flex 5/6kg, TEIN EDFC Active Pro. Tuning Developments Remap 4-1 Manifold, TD resonated exhaust, decat/overpipe, AP Racing 4 Pot front brakes. [lover]
Back to top
User is offline
alfiembra
1986 Toyota MR2 Mk1a
PostPosted: Mon Mar 28, 2011 8:25 pm    Post subject: Reply with quote Reply with quote including images
HeHeHe [d'oh!] [d'oh!] standard IT answer to everything switch it of and switch it back on again I'm surprised Max hasn't been on to suggest that before now. [Mr. Green]
Alan
Back to top
User is offline
toxo
PostPosted: Mon Mar 28, 2011 8:28 pm    Post subject: Reply with quote Reply with quote including images
Unfortunately unless it was a professionaly produced mod from a tuner garage, you're unlikely to be able to find out what it does and what the dip switches are for without ripping it to bits, and there's never a guarantee that it'll go back together again!
Jon Sole is your man for that, though.
Back to top
User is offline
JMR_AW11
1989 Toyota MR2 Mk1b
PostPosted: Mon Mar 28, 2011 9:00 pm    Post subject: Reply with quote Reply with quote including images
The board looks to be about 10 or 11 years old possibly a clone of Denso design from the 80s.
The trimpot is probably a crude way of fudging an analogue sensor.
The clue is in the words IN and OUT on the PCB plus it looks like it connects via these two flying IN OUT wires to the ECU main connector. Is it in series with a sensor?
The DIP switches probably allow selection of different ROM versions. The 27C256 has loads of capacity and can store several versions of the original ROM code. I'd guess the switches affect the address decoding on the EPROM.
Play with these switches at your peril [Smile]
Why not dump out the contents of the EPROM?
Back to top
User is offline
shish
PostPosted: Mon Mar 28, 2011 10:21 pm    Post subject: Reply with quote Reply with quote including images
have nothing to dump eproms sorry
am a little annoyed actually, i was hoping it would be a standard ecu so we could put a unichip or something similar on it...
i guess it shouldn't be too hard to find a stock one we can use.
Back to top
User is offline
toxo
PostPosted: Mon Mar 28, 2011 10:25 pm    Post subject: Reply with quote Reply with quote including images
Have a read of this Lauren...
http://www.toymods.org.au/forums/showthread.php?43434-Prototype-Programmable-4AG-ECU-Anyone-know-anything-56k/page2
Back to top
User is offline
shish
PostPosted: Mon Mar 28, 2011 10:36 pm    Post subject: Reply with quote Reply with quote including images
yea, was reading that page earlier, nothing that looks like ours
Back to top
User is offline
JMR_AW11
PostPosted: Mon Mar 28, 2011 10:50 pm    Post subject: Reply with quote Reply with quote including images
If you refit a stock ECU you might have rev limiter issues. If it's cammed up then it probably wants to rev close to 8000rpm.
Where does that ECU rev limit?
I'd expect one of the dip switch options will select a different rev limit but that really is a wild guess.
If you do ever get someone to dump the EPROM then make sure they use a reader rather than something that can also produce program voltages. It only takes a bit of finger trouble to corrupt the EPROM otherwise.
I had similar issues on ebay. On many occasions I bought stock ECUs only to find they had Techtom boards inside or other mods. Not much use to me [Sad]
I do have some AE86 ECUs here (somewhere) but these are for the UK version so no use to you. You may have to get one from Japan although there should be loads available.
Back to top
User is offline
shish
PostPosted: Mon Mar 28, 2011 11:06 pm    Post subject: Reply with quote Reply with quote including images
@JMR_AW11
looking at the pics it seems to be tied into the oxygen sensor and R115
Back to top
User is offline
shish
PostPosted: Mon Mar 28, 2011 11:11 pm    Post subject: Reply with quote Reply with quote including images
going by the 86 forums we should be able to pick one up... but for the forseeable we'll be using what we have.
Back to top
User is offline
Lauren
PostPosted: Tue Mar 29, 2011 7:26 am    Post subject: Reply with quote Reply with quote including images
I've revved it to 8K and beyond and still not found the limiter. Trouble is, once it goes off the scale it's difficult to know where you're at.
Think will likely rolling road it and see if everything is okay fueling wise.
What did notice is how much smoother it was after putting the ECU back in, really is pulling very well indeed.
Back to top
User is offline
JMR_AW11
PostPosted: Tue Mar 29, 2011 10:22 am    Post subject: Reply with quote Reply with quote including images
shish wrote:
@JMR_AW11
That's a weird one...
Maybe the trimpot calibrates a wideband (or alternative) sensor to mimic a stock narrowband sensor by aligning the switching threshold to be the same as a narrowband one.
If so then it's effectively a closed loop mixture control pot plus you get to monitor AFR on the wideband?
Just a guess though [Smile]
Back to top
User is offline
shish
PostPosted: Tue Mar 29, 2011 8:07 pm    Post subject: Reply with quote Reply with quote including images
tbh i didn't check properly and failed to take proper pics...
...i thought the black and red wires were just for additional ground a power lines in addition to the ones from the CPU socket, i should have paid more attention
going by the charts it's the OX line, but looks like i can see IDL (idle switch) screened on the PCB in the pics!
Back to top
User is offline
PW@Woodsport
IMOC Affiliated Company
PostPosted: Thu Mar 31, 2011 6:32 pm    Post subject: Reply with quote Reply with quote including images
Lauren i've found the cure for your flatspot....
http://cgi.ebay.co.uk/TOYOTA-COROLLA-AE86-4AGE-HKS-TURBO-KIT-RARE-/270728179605?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f08a82f95#ht_500wt_1156
[thumleft]
_________________
Back to top
User is offline
Lauren
PostPosted: Thu Mar 31, 2011 8:18 pm    Post subject: Reply with quote Reply with quote including images
LOL Paul! Stop it! [Wink]
Nice bit of kit. Turbos seem not to be popular in the eight-six world. So I'm not convinced anyone would talk to me if I did that.
But, don't worry the flat spot is well and truly gone now. Cannot believe how smooth it is all the way to the redline. It's a real peachy 4AGE. [thumbsup]
Just need to clean the throttle and ICV this weekend as it can stall if the headlights are on. AC idle up works perfectly in contrast, so I reckon we can sort that fairly easily. [thumbsup]
Back to top
User is offline
Steve Horrocks
PostPosted: Thu Mar 31, 2011 8:27 pm    Post subject: Reply with quote Reply with quote including images
What did you do?
Back to top
User is offline
PW@Woodsport
PostPosted: Thu Mar 31, 2011 8:29 pm    Post subject: Reply with quote Reply with quote including images
Well on the mk1 it uses a VSV for idle up when the lights are on etc a separate system to the AC idle up valve, now I don't know if the 86 uses the same set up but I'd check the idle up VSV if it has one.
Alternatively if the idle up is not working at all (could be that fiddled with ECU is disabled in that respect who knows?) , you could always trigger the AC idle up valve with the headlight signal, that will fix it.
Back to top
User is offline
Lauren
PostPosted: Thu Mar 31, 2011 8:58 pm    Post subject: Reply with quote Reply with quote including images
Paul, they are most definitely separate. Yes could utilise the AC idle up, but hopefully we can fix the general idle up.
General idle up doesn't work too well, the revs go up and down. Mark did say though he noticed one was partially blocked, so there's a likely culprit really.
Back to top
User is offline
Lauren
PostPosted: Sat Apr 02, 2011 1:42 pm    Post subject: Reply with quote Reply with quote including images
Okay had a look at the cams. HKS 264s. Other marking on them was '11'. Not sure if this refers to lift or not, sounds a little high if it does.
Back to top
User is offline
Display posts from previous:
Page 3 of 5
Jump to:
