BOV and Rev1/2's do they go together?
Over on MR2oc, under 'General Banter'. Will it knacker her engine?
Re: BOV and Rev1/2's do they go together?
Hi,
It wont nacker the engine, but it will make it overfuel on lift off as the AFM cant detect the air flow properly.
I dont think it's too much of a problem. Others on here would disagree!
Paul.
Paul.
ryan wrote:Over on MR2oc, under 'General Banter'. Will it knacker her engine?
There was a post on the old format IMOC about this. JJ said it won't.
I have a Blitz SS BOV on my rev 1 for a while now.......can't tell the difference except the sound!
shame you'll sound like a bus now!
i hav a trd bov on my rev2 and its fine no difference at all apart from the lovely noise it makes
Got an Apexi bov on mine. Dont seem to have any problems as yet - nothing apparent when I got the car set up at Thor either.
yep same here i have an hks ssqv and have had no problems
- Driftlimits Performance
- IMOC Affiliated Company
Luize,
Do you know if its the Greddy DV for the high powered MR2s? Just that my friend had one of these not so long ago and he was getting compressor stall as it wasn't dumping enough air, which although sounds really cool, does no good to the turbo.
If you like I could get you an HKS dump valve with everything you need to fit it for £50?
