Ariel rev3
Ariel rev3
Are all Rev 1 2 4 mk2 Ariel compatable mines gone on my rev3
Re: Ariel rev3
Dont think so.
I had this problem a few years ago and got a number of used ones to try and make a good one and failed.
There are at least 3 different control boxes (black, brown, green) that are not interchangeable unless replacing the whole aerial assembly and not just the bit that is broke. I have seen all of these of rev3 turbos.
I think there were also 2 different size connectors.
Toyota might still be able to get you the right part numbers from your chassis number.
New one from Toyota was mega expensive so I got a generic new one from local ICE installer... who will also fit an ISO connector to the loom making it easier if you ever need to do it again.
